Author Topic: Pipe material description  (Read 3207 times)
PHX cadie
« on: September 03, 2017, 03:14:49 PM »
I seem unable to change the pipe material description. Following a youtube vid
https://www.youtube.com/watch?v=hUiH5SJiiWc
Starting @ 4:50 (Create Design>Part Builder>, select Conc pipe>Modify Part Sizes button, select Size Parameters, rt clk, edit, change from Reinforced Concrete Pipe to RCP) I can follow along up to the point of saving the AeccCircularConcretePipe_Imperial.dwg. The pop up says its a read-only file.
Never too far from my Windows 3.1 for dummies book, Windows Explorer claims the file is not read-only, hidden, etc
If C3D is using the file, how can the youtube dude modify it?
Bottom line:
How can I change the Pipe material description from "Reinforced Concrete Pipe" ( waaaaay long) to "RCP"?
Many thanks again!!!
Acad 2013 and XM
Back when High Tech meant you had an adjustable triangle
Re: Pipe material description
« Reply #1 on: September 06, 2017, 08:48:01 AM »
You don't have to modify/create a new pipe catalog to do this.
However IF you do it is advised in HELP file that you copy the pipe catalog folder
to someplace safe, and then set your pipe catalog path to use that one.
Because by default the parts catalog is READ ONLY to keep us from messing it up.
Change the material name/type in your parts list
or you can manually edit the description for any pipe or all pipes in properties window
PHX cadie
« Reply #2 on: September 06, 2017, 03:36:26 PM »
Thank you for the reply
One prob fixed was that I didn't have rights to the material library file
Mike:
I found the "Network Parts List", but it reads "12 inch Concrete Pipe", not 12" Reinforced Concrete Pipe" so I'm hesitate to change it. Is that where the pipe label comes from?
Many thanks again
Acad 2013 and XM
« Reply #3 on: September 06, 2017, 05:26:27 PM »
Mike:
Many thanks again
Just change it....in the parts list, in the file you need that description...it will NOT affect any other files or data....
The snip I posted is the part description...in the parts list, not part builder......
As you can see you don't have 12" RGRCP; and neither did I until I edited it
PHX cadie
« Reply #4 on: September 06, 2017, 07:18:59 PM »
Thanks!!
Acad 2013 and XM
PHX cadie
« Reply #5 on: September 09, 2017, 07:39:59 PM »
sorry for the delay ( have to wait for weekend playtime)
Thank You Mr. Farrell
Acad 2013 and XM
