Author Topic: How to select sub entity of another sub entity for processing?  (Read 1298 times)
Hrishikesh
« on: September 02, 2017, 05:08:03 AM »
Hello Community,
I have to give continues dimensions to blocks, these blocks are part of another block (blocks inside block) & this main block is in xref.
Xref-->main block-->blocks ( I have to give dimensions for)
How can i get insertion point of these blocks & give continues dimensions in a single command?
Thanks in advance,
DEVITG
Re: How to select sub entity of another sub entity for processing?
« Reply #1 on: September 03, 2017, 12:55:05 PM »
Please show the DGW and it´s ref DWG
FaheyLynn
« Reply #2 on: September 07, 2017, 05:17:42 AM »
I will try to see. Thank you for this post. I have nothing to help.
