Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
Explode block with annotative state
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Explode block with annotative state (Read 1504 times)
latour_g
Newt
on:
August 28, 2017, 04:01:29 PM »
I need to explode a block that contains annotative objects. The problem I have is the annotative state get loose after the explode. Here is what I have :
Code - C#:
[Select]
DBObjectCollection coll
new
DBObjectCollection
br
Explode
coll
System.
Collections
IEnumerator
iter
coll
GetEnumerator
while
iter
MoveNext
Entity ent
Entity
iter
Current
ent
SetDatabaseDefaults
btr
AppendEntity
ent
tr
AddNewlyCreatedDBObject
ent,
true
br
Erase
coll
Dispose
When debugging, I see that "ent" has AnnotativeState at true.
Logged
Bryco
Water Moccasin
Re: Explode block with annotative state
Reply #1 on:
August 29, 2017, 12:06:20 AM »
That may involve deep clone. I clone objects and they do not copy the xdata so you may have the same problem.
basically you deep clone the objects from the block and transform them using the blockref.BlockTransform
Logged
latour_g
Newt
Reply #2 on:
August 30, 2017, 03:05:55 PM »
Thanks Bryco I'm gonna check this out
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
