Author Topic: Offsetting Featurelines  (Read 2942 times)
nobody
  • .net stuff
« on: August 28, 2017, 02:22:20 PM »
Is there a difference between using a stepped offset with 0 elevation difference than simply using the offset command?
Re: Offsetting Featurelines
« Reply #1 on: August 28, 2017, 02:44:28 PM »
Yes you miss the chance to alter the elevations IF you need/want to during the offset process.
It still remains a feature line with regular offset command, some civil objects revert to polylines when offset using autocad commands.
nobody
  • .net stuff
« Reply #2 on: August 28, 2017, 03:58:47 PM »
Of course :) But does the standard offset command degrade the featureline in a way that isn't when using the stepped offset command?
« Reply #3 on: August 28, 2017, 05:18:28 PM »
Ne Degradation that I am aware of.
