Author Topic: TblSearch for mleaderstyles??  (Read 1657 times)
Matt__W
  • I like my water diluted.
« on: August 28, 2017, 01:43:34 PM »
Is there not a table for mleaderstyles? I'm trying to determine if a style exists in a drawing.
Autodesk Expert Elite
Re: TblSearch for mleaderstyles??
« Reply #1 on: August 28, 2017, 01:46:19 PM »
This works for me:
  1. (and (setq d (dictsearch (namedobjdict) "acad_mleaderstyle"))
  2.      (setq ed (cdr (assoc -1 d)))
  3.      (dictsearch ed mlstylename)
  4. )
Grrr1337
« Reply #2 on: August 28, 2017, 02:03:33 PM »
Another variation with activex:
  1. (defun MleaderStylep ( nm )
  2.   (cond
  3.     (
  4.         (setq nm
  5.           (vl-catch-all-apply 'vla-item
  6.             (list (vla-item (vla-get-dictionaries (vla-get-activedocument (vlax-get-acad-object))) "ACAD_MLEADERSTYLE") nm)
  7.           )
  8.         )
  9.       )
  10.       (prompt (strcat "\nError: " (vl-catch-all-error-message nm)))
  11.     )
  12.     ( nm )
  13.   )
  14. ); defun MleaderStylep
  15.
(apply ''((a b c)(a b c))
vevo.bg
Matt__W
« Reply #3 on: August 28, 2017, 02:18:49 PM »
Thanks, Ron. Shortly after posting I came across basically the same thing you posted (that's usually how it works, right?).
And thanks Grrr1337 for your input.  :)
« Reply #4 on: August 28, 2017, 03:12:22 PM »
Glad to help :)
