Author Topic: Is there any way that I can export the image other than jpgout command?  (Read 3664 times)
cmwade77
Re: Is there any way that I can export the image other than jpgout command?
« Reply #15 on: September 05, 2017, 07:59:48 PM »
What we have setup in the past when we need an image format is we plot to PDF, then use a command line PDF to Image converter to convert the PDF to an Image, this way everything can be automated within a LISP routine and you get everything to the correct scale and a quality image.
Didge
« Reply #16 on: September 18, 2017, 10:48:03 AM »
As above.
Plus, the MS Word installation media usually comes with an optional extension to enable the direct import of DWG and DXF files.
These filters are usually disabled for a "Typical Install" so a "Custom Install" is required instead.
Think Slow......
