Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
Object Distance from Another
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Object Distance from Another (Read 1566 times)
nobody
Swamp Rat
.net stuff
on:
August 25, 2017, 12:10:22 AM »
Is there a way to check a polylines distance from another object without iterating through every point?
Logged
It's Alive!
Retired
Needs a day job
AKA Daniel
WWW
Re: Object Distance from Another
Reply #1 on:
August 25, 2017, 03:12:42 AM »
maybe AcDbCurve::getClosestPointTo ?
Logged
https://github.com/CEXT-Dan/PyRx
https://pyarx.blogspot.com/
Bryco
Water Moccasin
Reply #2 on:
August 25, 2017, 11:32:44 AM »
Usually you use the bounding box first to check whether the object is within the desired range, then find out if the polyline is simpler than the object you are checking to define the next step
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
