Author Topic: Help with lisp Import data between autocad and google earth  (Read 3124 times)
anhquang1989
« on: August 22, 2017, 01:35:12 AM »
I find that there are many programs that switch between autocad and google earth.
But I can not use them in Vietnam because Vietnam uses a separate coordinate system that is VN 2000
Article 1. Now use the system parameters to switch between international coordinate system
WGS-84 ( zone 48 and 49)coordinate system of national and VN-2000 is as follows:
1. Parameter shifts the origin:
-191.90441429 M; -39.30318279 m; -111.45032835 m.
2. The coordinate rotation:
-0.00928836 " ; 0.01975479" ; -0.00427372".
3. Scaling length:
k = 1.000000252906278
Article2: With each province using a separate axis
http://alophukien.net/kinh-tuyen-truc-he-toa-do-vn2000-cho-cac-tinh
Look forward to your help.Thank you very much!
« Last Edit: August 22, 2017, 01:38:45 AM by anhquang1989 »
VovKa
  • Ukraine
Re: Help with lisp Import data between autocad and google earth
« Reply #1 on: August 23, 2017, 07:35:28 AM »
i believe you should contact the authors of those programs and ask for VN 2000 support
anhquang1989
« Reply #2 on: August 23, 2017, 09:44:42 AM »
Hi. Vovka.
I've seen them but most of the programs are build with vba and I still have not contacted the author.
Especially I love lisp so I hope to see it and I believe that some other countries have similar problems, so when it is established it will help a lot.
VovKa
  • Ukraine
« Reply #3 on: August 23, 2017, 10:58:24 AM »
i would not call them "problems"
it's a standard situation for coordinate systems that were realized before WGS84 era
and it could be worse
for example in Ukraine to covert old  soviet coordinates to the new WGS84 based system one must use not only axis shift and rotation but also affine transformations based on the TIN
anhquang1989
« Reply #4 on: August 23, 2017, 11:55:52 PM »
Yes. I agree with you.
VovKa
  • Ukraine
« Reply #5 on: August 24, 2017, 04:06:07 PM »
anhquang1989, today i had some free time to look closely into kml documentation
as a result i've written the function to convert dwg entities into kml format
i plan to add it to my IRT program (https://www.theswamp.org/index.php?topic=47908.0)
anhquang1989
« Reply #6 on: August 25, 2017, 02:38:41 AM »
That great. I really hope to see it.. thank you very much. Vovka  :smitten:
