Dialog Box display...see both picks. The issue has been fixed by their help below:
#1. Double display of text_part labels
In the AutoCAD's DCL documentation (
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-AutoLISP/files/GUID-6F7C60D6-ADCC-48B0-83F9-A69F88D87436-htm.html), tiles have this definition:
name : item1 [ : item2 : item3 … ]
attribute = value;
where each item is a previously defined tile.
So the meaning of the inheritance is restricted to attributes only on AutoCAD, whereas on BricsCAD everything is inherited.
This multiple inheritance [ : item2 : item3 … ] is not used in practice. It is not supported in BricsCAD. We were noticed only once before in a single SR. In that SR the user simply removed the multiple inheritance, even in that single case it was an unintentional coincidence.
The code ":arch_cmdname { arch_cmdname;}" might be changed to: "arch_cmdname;" since arch_cmdname does not have any attributes.
Is it acceptable to just use arch_cmdname;?
