Author Topic: BricsCAD Dialog Box Sizing Problem  (Read 2010 times)
GDF
« on: August 17, 2017, 07:46:35 PM »
I'm trying out BricsCAD for the first time; and I'm having problems with dialog box width size, from my dcl files.
Re: BricsCAD Dialog Box Sizing Problem
« Reply #1 on: August 17, 2017, 08:15:32 PM »
Probably best to post HERE.
« Reply #2 on: August 17, 2017, 11:23:02 PM »
I've been using BricsCAD for 6 months at least & no DCL problems yet.
But my dialogs are not as complex as some of yours.
GDF
« Reply #3 on: August 22, 2017, 10:34:20 AM »
Thanks for the feedback
GDF
« Reply #4 on: September 03, 2017, 08:08:55 PM »
I have gotten all of my issues solved from BricsCAD support team!
« Reply #5 on: September 04, 2017, 02:37:31 PM »
They do seem to support the product.
What, in a nut shell, was the issue?
GDF
« Reply #6 on: September 05, 2017, 12:27:09 PM »
Dialog Box display...see both picks. The issue has been fixed by their help below:
#1. Double display of text_part labels
 In the AutoCAD's DCL documentation (https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-AutoLISP/files/GUID-6F7C60D6-ADCC-48B0-83F9-A69F88D87436-htm.html), tiles have this definition:
 name : item1 [ : item2 : item3 … ]
attribute = value;
where each item is a previously defined tile.
So the meaning of the inheritance is restricted to attributes only on AutoCAD, whereas on BricsCAD everything is inherited.
This multiple inheritance [ : item2 : item3 … ] is not used in practice. It is not supported in BricsCAD. We were noticed only once before in a single SR. In that SR the user simply removed the multiple inheritance, even in that single case it was an unintentional coincidence.
The code ":arch_cmdname { arch_cmdname;}" might be changed to: "arch_cmdname;" since arch_cmdname does not have any attributes.
 Is it acceptable to just use arch_cmdname;?
« Reply #7 on: September 05, 2017, 01:21:01 PM »
Thanks for sharing
