Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Help with slope lisp
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Help with slope lisp (Read 1531 times)
pedroantonio
Guest
on:
August 07, 2017, 04:51:50 AM »
Hi .I am using a slope lisp ,but i want to do same changes
This lisp give you two options
1) to select 2 points and then pick a point to insert the slope text
2)select a line and then pic a point to insert the slope text
The changes i want to do is
1) Automatically insert the slope text in the midle of the line (over the line)
2) Correct the angle of the text. I want to align the text with the line
Code - Auto/Visual Lisp:
[Select]
defun
c:TanLineanot
doc spc
*error*
TH:UnDo
TH:StartUnDo p1 p2 p3 scl ht
tan2 TL
Line TH:UnDo
;;; Authour : Hasan Asos -> Modified by Tharwat
vl-load-com
COMMAND
"_layer"
"_m"
"_slope"
"_c"
"140"
command
"-style"
"_TanLine"
"wgsimpl.shx"
"_annotative"
"_yes"
"_no"
1.75
1.0
0.0
"_no"
"_no"
and
setq
doc
cond
doc
vla-get-ActiveDocument
vlax-get-Acad-Object
setq
spc
if
zerop
vla-get-activespace
doc
if
vla-get-mspace
doc
:vlax-true
vla-get-modelspace
doc
vla-get-paperspace
doc
vla-get-modelspace
doc
defun
*error*
msg
and
TH:UnDo
vla-EndUndoMark
doc
or
wcmatch
strcase
msg
"*BREAK,*CANCEL*,*EXIT*"
princ
strcat
\n
** Error: "
msg
princ
setq
TH:StartUnDo
vla-StartUndoMark
doc
initget
"Line Points"
if
eq
setq
TL
sel
getkword
strcat
\n
Specify line or point [Line/Points]: "
"< Line >"
"Points"
progn
setq
p1
getpoint
\n
Specify 1 point : "
setq
p2
getpoint
p1
\n
Specify 2 point : "
setq
p3
getpoint
\n
Specify the insert point : "
setq
tan2
cadr
p2
cadr
p1
car
p2
car
p1
entmake
list
cons
0
"LINE"
cons
10
trans
p1
1
0
cons
11
trans
p2
1
0
vla-AddText
spc
strcat
rtos
abs
tan2
100
2
2
vlax-3d-point
trans
p3
1
0
getvar
'TEXTSIZE
getvar
'cannoscalevalue
progn
prompt
\n
Select line: "
setq
TL
Line
ssget
0
"LINE"
setq
e
ssname
TL
Line
0
setq
p1
cdr
assoc
10
entget
e
setq
p2
cdr
assoc
11
entget
e
setq
p3
getpoint
\n
setq
tan2
cadr
p2
cadr
p1
car
p2
car
p1
vla-AddText
spc
strcat
rtos
abs
tan2
100
2
2
vlax-3d-point
trans
p3
1
0
1.75
setq
TH:UnDo
vla-EndUndoMark
Doc
princ
\n
princ
Logged
HasanCAD
Swamp Rat
Re: Help with slope lisp
Reply #1 on:
August 08, 2017, 07:43:29 AM »
Give this a try
[Select]
defun
c:TanLineanot
doc spc
*error*
TH:UnDo TH:StartUnDo
p1 p2 p3 scl ht
tan2 TL
Line TH:UnDo ang doc
e ff myline objstyle p12dist
p1x p1y p2x p2y r
ang
styles th:undo tl
sel txt
;; Readable - Lee Mac
;; Returns an angle corrected for text readability.
defun
LM:readable
a
lambda
a
if
and
pi
0.5
a
a
pi
1.5
LM:readable
a pi
a
rem
a pi pi
pi pi
defun
*error*
msg
and
TH:UnDo
vla-EndUndoMark
doc
or
wcmatch
strcase
msg
princ
strcat
\n
** Error: "
msg
princ
vl-load-com
foreach
args '
"_SLOPE"
140
"Continuous"
0.15
t
0
"SLOPE VALUE"
apply
'lyrmk args
;(command "-style" "_TanLine" "wgsimpl.shx" "_annotative" "_yes" "_no" 1.75 1.0 0.0 "_no" "_no" "" "")
and
setq
doc
cond
doc
setq
spc
if
zerop
vla-get-activespace
doc
if
vla-get-mspace
doc
:vlax-true
vla-get-modelspace
doc
vla-get-paperspace
doc
vla-get-modelspace
doc
setq
styles
vla-get-textstyles
doc
setq
objStyle
vla-add
styles
"_TanLine"
setq
ff
"c:
Windows
fonts
swisscbo.ttf"
vla-put-fontfile
objStyle ff
vla-put-activetextstyle
doc objStyle
setq
TH:StartUnDo
vla-StartUndoMark
doc
initget
"Line Points"
if
eq
setq
TL
sel
getkword
strcat
\n
"< Line >"
"Points"
progn
setq
p1
getpoint
\n
Specify 1 point : "
setq
p2
getpoint
p1
\n
Specify 2 point : "
setq
p12dist
distance
p1 p2
setq
ang
angle
p1 p2
setq
R
ang
LM:readable ang
setq
p3
polar
p1 R
ang
p12dist
2.0
setq
tan2
cadr
p2
cadr
p1
car
p2
car
p1
setq
myline
vla-addline
spc
vlax-3d-point
trans
p1
1
0
vlax-3d-point
trans
p2
1
0
vla-put-layer
myline
"_SLOPE"
setq
txt
vla-AddText
spc
strcat
rtos
abs
tan2
100
2
2
vlax-3d-point
trans
p3
1
0
getvar
'TEXTSIZE
getvar
'cannoscalevalue
vla-put-rotation
txt R
ang
progn
prompt
\n
Select line: "
setq
TL
Line
ssget
0
"LINE"
setq
e
ssname
TL
Line
0
setq
p1
cdr
assoc
10
entget
e
setq
p2
cdr
assoc
11
entget
e
setq
p1
trans
p1
1
0
p2
trans
p2
1
0
p1X
min
nth
0
p1
nth
0
p2
p1Y
min
nth
1
p1
nth
1
p2
p2X
max
nth
0
p1
nth
0
p2
p2Y
max
nth
1
p1
nth
1
p2
setq
p1
list
p1X p1Y
0
p2
list
p2X p2Y
0
setq
p12dist
distance
p1 p2
setq
ang
angle
p1 p2
setq
R
ang
LM:readable ang
setq
p3
polar
p1 R
ang
p12dist
2.0
setq
tan2
cadr
p2
cadr
p1
car
p2
car
p1
setq
txt
vla-AddText
spc
strcat
rtos
abs
tan2
100
2
2
vlax-3d-point
trans
p3
1
0
getvar
'TEXTSIZE
getvar
'cannoscalevalue
vla-put-rotation
txt R
ang
vla-put-textstyle
txt
"_TanLine"
setq
TH:UnDo
vla-EndUndoMark
Doc
princ
\n
princ
Logged
Sorry for my English.
Donate to Theswamp
www.sergiwa.com
pedroantonio
Guest
Reply #2 on:
August 08, 2017, 09:24:26 AM »
hi HasanCAD.I try your code but gives me this error
** Error: no function definition: nil **
Logged
HasanCAD
Swamp Rat
Reply #3 on:
August 08, 2017, 10:32:10 AM »
There was missing subroutine
Try this
[Select]
defun
c:TanLineanot
doc spc
*error*
p1 p2 p3 scl ht
tan2 TL
p1x p1y p2x p2y r
ang
styles th:undo tl
sel txt
defun
LM:readable
a
lambda
a
if
and
pi
0.5
a
a
pi
1.5
LM:readable
a pi
a
rem
a pi pi
pi pi
defun
*error*
msg
and
TH:UnDo
vla-EndUndoMark
doc
or
wcmatch
strcase
msg
princ
strcat
\n
** Error: "
msg
princ
defun
lTload
lTyp
vl-load-com
if
not
tblsearch
"LTYPE"
lTyp
vla
load
vla-get-Linetypes
vlax-get-acad-object
lTyp
if
getvar
"MEASUREMENT"
0
"acad.lin"
"acadiso.lin"
defun
lyrmk
Nme Col lTyp lWgt Plt trns dsc
lay lyrs cmd
;lee mac
;http://www.cadtutor.net/forum/showthread.php?36882-Check-create-layer-issue-in-Lisp&p=243520&viewfull=1#post243520
vl-load-com
setq
cmd
getvar
'cmdecho
setvar
'cmdecho
0
if
not
tblsearch
"LAYER"
Nme
progn
setq
lyrs
vla-get-layers
setq
lay
vla-add
lyrs Nme
;(mdfy)
setq
entVL
vlax
ename
vla-object
tblobjname
"LAYER"
Nme
and
Col
vla-put-Color
entVL Col
and
lTyp
lTload lTyp
vla-put-Linetype
entVL lTyp
; (and lWgt (vla-put-LineWeight entVL (eval (read (strcat "acLnWt" lWgt)))))
and
lWgt
vl-cmdf
"_.-layer"
"_LWeight"
lWgt Nme
and
not
Plt
vla-put-Plottable
entVL
:vlax-false
and
setq
LyrDs
vlax-put-property
entVL 'Description dsc
vl-cmdf
"_.-layer"
"_TR"
trns Nme
progn
;(mdfy)
setq
entVL
vlax
ename
vla-object
tblobjname
"LAYER"
Nme
and
Col
vla-put-Color
entVL Col
and
lTyp
lTload lTyp
vla-put-Linetype
entVL lTyp
and
lWgt
vl-cmdf
"_.-layer"
"_LWeight"
lWgt Nme
and
not
Plt
vla-put-Plottable
entVL
:vlax-false
and
setq
LyrDs
vlax-put-property
vl-cmdf
"_.-layer"
"_TR"
trns Nme
setvar
'cmdecho cmd
vl-load-com
foreach
args '
"_SLOPE"
140
"Continuous"
0.15
t
0
"SLOPE VALUE"
apply
'lyrmk args
and
setq
doc
cond
doc
setq
spc
if
zerop
vla-get-activespace
doc
if
vla-get-mspace
doc
:vlax-true
vla-get-modelspace
doc
vla-get-paperspace
doc
vla-get-modelspace
doc
setq
styles
vla-get-textstyles
doc
setq
objStyle
vla-add
styles
"_TanLine"
setq
ff
"c:
Windows
fonts
swisscbo.ttf"
vla-put-fontfile
objStyle ff
doc objStyle
setq
TH:StartUnDo
vla-StartUndoMark
doc
initget
"Line Points"
if
eq
setq
TL
sel
getkword
strcat
\n
"< Line >"
"Points"
progn
setq
p1
getpoint
\n
Specify 1 point : "
setq
p2
getpoint
p1
\n
Specify 2 point : "
setq
p12dist
distance
p1 p2
setq
ang
angle
p1 p2
setq
R
ang
LM:readable ang
setq
p3
polar
p1 R
ang
p12dist
2.0
setq
tan2
cadr
p2
cadr
p1
car
p2
car
p1
setq
myline
vla-addline
spc
vlax-3d-point
trans
p1
1
0
vlax-3d-point
trans
p2
1
0
vla-put-layer
myline
"_SLOPE"
setq
txt
vla-AddText
spc
strcat
rtos
abs
tan2
100
2
2
vlax-3d-point
trans
p3
1
0
getvar
'TEXTSIZE
getvar
'cannoscalevalue
vla-put-rotation
txt R
ang
progn
prompt
\n
Select line: "
setq
TL
Line
ssget
0
"LINE"
setq
e
ssname
TL
Line
0
setq
p1
cdr
assoc
10
entget
e
setq
p2
cdr
assoc
11
entget
e
setq
p1
trans
p1
1
0
p2
trans
p2
1
0
p1X
min
nth
0
p1
nth
0
p2
p1Y
min
nth
1
p1
nth
1
p2
p2X
max
nth
0
p1
nth
0
p2
p2Y
max
nth
1
p1
nth
1
p2
setq
p1
list
p1X p1Y
0
p2
list
p2X p2Y
0
setq
p12dist
distance
p1 p2
setq
ang
angle
p1 p2
setq
R
ang
LM:readable ang
setq
p3
polar
p1 R
ang
p12dist
2.0
setq
tan2
cadr
p2
cadr
p1
car
p2
car
p1
setq
txt
vla-AddText
spc
strcat
rtos
abs
tan2
100
2
2
vlax-3d-point
trans
p3
1
0
getvar
'TEXTSIZE
getvar
'cannoscalevalue
vla-put-rotation
txt R
ang
vla-put-textstyle
txt
"_TanLine"
setq
TH:UnDo
vla-EndUndoMark
Doc
princ
\n
princ
Logged
Donate to Theswamp
www.sergiwa.com
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
