Author Topic: (vlax-curve-getpointatparam haupt_achse 0) -> nil?  (Read 1648 times)
Peter2
« on: August 07, 2017, 04:08:59 AM »
I supposed that the "param 0" would return the starting point of my curve - but it returns nil. The end-param (9 in my example) returns the endpoinbt, and the "dist 0" returns also the starting point. Can it be explained why the "start parameter 0" returns nil instead of the starting point???
  1. nil
  2.
  3. Befehl: (vlax-curve-getpointatparam haupt_achse 9)
  4. (811474.0 184382.0 0.0)
  5.
  6. Befehl: (vlax-curve-getpointatparam haupt_achse 0.000001)
  7. (811350.0 184319.0 0.0)
  8.
  9. Befehl: (vlax-curve-getpointatdist haupt_achse 0.00000)
  10. (811350.0 184319.0 0.0)
  11.
Peter
BricsCAD V23
roy_043
  • BricsCAD 18
Re: (vlax-curve-getpointatparam haupt_achse 0) -> nil?
« Reply #1 on: August 07, 2017, 04:27:23 AM »
Move the object closer to the origin and repeat the test.
Peter2
« Reply #2 on: August 07, 2017, 04:59:27 AM »
Although this could only be an experimental solution - I still get nil
Peter
BricsCAD V23
roy_043
  • BricsCAD 18
« Reply #3 on: August 07, 2017, 09:12:53 AM »
What does this return?:
« Last Edit: August 07, 2017, 09:16:07 AM by roy_043 »
Peter2
« Reply #4 on: August 07, 2017, 11:11:35 AM »
0.00000000
Peter
BricsCAD V23
roy_043
  • BricsCAD 18
« Reply #5 on: August 07, 2017, 12:33:59 PM »
The issue is of course: Zero? Or almost zero?
But from a discussion with Bricsys I know that the AutoCAD curve functions can produce unexpected results.
I suggest you create a workaround.
« Reply #6 on: August 07, 2017, 01:05:19 PM »
How about:
ribarm
  • Marko Ribar, architect
« Reply #7 on: August 07, 2017, 01:20:26 PM »
That's the same as just :
M.R. on Youtube
