Thank you very much (didn't expect a reply over w/e)
Found the text Component Editor, under each component name clk'd ... in the text, contents box and changed to upper case, clk the arrow button to push over to the dialog box (something I saw on youtube, right/wrong?) and clk ok it will not stay. If I immediately go back to Text Comp Editor it reverts back to preserve case. I made a copy of the label style so I don't believe any settings to be locked
What could I be doing wrong?
@ second glance I see a company employee has modified the pipe styles, maybe I should hold off.
Thank you for your help, I may be back later (seriously doubt the company is going to lower case text)
