Author Topic: Upper case pipe/structure labels  (Read 2562 times)
PHX cadie
« on: August 05, 2017, 11:47:47 PM »
Being very new to C3d, how do I change pipe/structure labels to caps?
I looked into help and read about "upper" but I have no idea how to implement
Thxs!!
Acad 2013 and XM
Re: Upper case pipe/structure labels
« Reply #1 on: August 06, 2017, 01:42:16 PM »
It's in the Label Style:
PHX cadie
« Reply #2 on: August 06, 2017, 08:25:34 PM »
Thank you very much (didn't expect a reply over w/e)
Found the text Component Editor, under each component name clk'd ... in the text, contents box and changed to upper case, clk the arrow button to push over to the dialog box (something I saw on youtube, right/wrong?) and clk ok it will not stay. If I immediately go back to Text Comp Editor it reverts back to preserve case. I made a copy of the label style so I don't believe any settings to be locked
What could I be doing wrong?
@ second glance I see a company employee has modified the pipe styles, maybe I should hold off.
Thank you for your help, I may be back later (seriously doubt the company is going to lower case text)
« Last Edit: August 06, 2017, 08:37:12 PM by PHX cadie »
Acad 2013 and XM
PHX cadie
« Reply #3 on: September 03, 2017, 02:57:46 PM »
Got it!!!!!!!
I never dragged across the material name, change to uppercase then hit the apply button
(did I mention I'm a newbie?)
Thank You, (don't go too far, have more questions)  :)
Acad 2013 and XM
