Author Topic: make a program running immediatly at the first execution  (Read 6528 times)
samideqlqpart
Re: make a program running immediatly at the first execution
« Reply #15 on: August 05, 2017, 08:11:10 AM »
hello
Mr Yuan have you the code in vb.net
cause my converter has problem with+=
public dlgProgress(
            ILongProcessingObject executingObj)
            : this()
            _executingObject = executingObj;
            _executingObject.ProcessingStarted +=
                new LongProcessStarted(ExecutingObject_ProcessStarted);
            _executingObject.ProcessingProgressed +=
                new LongProcessingProgressed(ExecutingObject_Progressed);
            _executingObject.ProcessingEnded +=
                new EventHandler(ExecutingObject_ProcessEnded);
            _executingObject.CloseProgressUIRequested +=
               new EventHandler(ExecutingObject_CloseProgressUIRequested);
Keith Brown
« Reply #16 on: August 05, 2017, 08:20:24 AM »
Use AddHandler and AddressOf in VB.NET.  All the code is doing is subscribing to events.
So for the first event you would have
AddHandler _executingObject.ProcessingStarted, AddressOf ExecutingObject_ProcessStarted.
samideqlqpart
« Reply #17 on: August 06, 2017, 07:11:07 PM »
i'm lost
what i have to do for displaying a progressbar  during this long time of waiting?
from the press the button of execution until the dispay of the drawing
to allow autocad load dll
ToolStripProgressBar...? doEvent....?
what are steps to do
thank you
MexicanCustard
« Reply #18 on: August 08, 2017, 07:30:20 AM »
i'm lost
thank you
Progress Bars get complicated in AutoCAD since database manipulation has to happen on the UI thread. You can you use AutoCAD's built in ProgressMeter().  Not great but better than nothing. Check out Kenan's Blog.  Or Norman's  Blog.
samideqlqpart
« Reply #19 on: August 09, 2017, 04:09:42 AM »
hi
yes i 've found it
and there is code in vb.net(with converter..)
Imports Autodesk.AutoCAD.Runtime
Imports System.Runtime.InteropServices
Imports System.Windows.Forms
Namespace ProgressMeterTest
    Public Class Cmds
        <CommandMethod("PB")> _
        Public Sub ProgressBarManaged()
            Dim pm As New ProgressMeter()
            pm.Start("Testing Progress Bar")
            pm.SetLimit(100)
            ' Now our lengthy operation
            For i As Integer = 0 To 100
                System.Threading.Thread.Sleep(5)
                ' Increment Progress Meter...
                pm.MeterProgress()
                ' This allows AutoCAD to repaint
                Application.DoEvents()
            Next
            pm.[Stop]()
    End Class
End Namespace
and an other most interresting code
Imports System
Imports System.Collections.Generic
Imports System.ComponentModel
Class FibonacciNumber
    Inherits Form
    Private progressStatusStrip As StatusStrip
    Private toolStripProgressBar As ToolStripProgressBar
    Private requestedCountControl As NumericUpDown
    Private goButton As Button
    Private outputTextBox As TextBox
    Private backgroundWorker As BackgroundWorker
    Private toolStripStatusLabel As ToolStripStatusLabel
    Private requestedCount As Integer
    Public Sub New()
        [Text] = "Fibonacci"
        ' Prepare the StatusStrip.
        progressStatusStrip = New StatusStrip()
        toolStripProgressBar = New ToolStripProgressBar()
        toolStripProgressBar.Enabled = False
        toolStripStatusLabel = New ToolStripStatusLabel()
        progressStatusStrip.Items.Add(toolStripProgressBar)
        progressStatusStrip.Items.Add(toolStripStatusLabel)
        Dim flp As New FlowLayoutPanel()
        flp.Dock = DockStyle.Top
        Dim beforeLabel As New Label()
        beforeLabel.Text = "Calculate the first "
        beforeLabel.AutoSize = True
        flp.Controls.Add(beforeLabel)
        requestedCountControl = New NumericUpDown()
        requestedCountControl.Maximum = 1000
        requestedCountControl.Minimum = 1
        requestedCountControl.Value = 100
        flp.Controls.Add(requestedCountControl)
        Dim afterLabel As New Label()
        afterLabel.Text = "Numbers in the Fibonacci sequence."
        afterLabel.AutoSize = True
        flp.Controls.Add(afterLabel)
        goButton = New Button()
        goButton.Text = "&Go"
        AddHandler goButton.Click, AddressOf button1_Click
        flp.Controls.Add(goButton)
        outputTextBox = New TextBox()
        outputTextBox.Multiline = True
        outputTextBox.ReadOnly = True
        outputTextBox.ScrollBars = ScrollBars.Vertical
        outputTextBox.Dock = DockStyle.Fill
        Controls.Add(outputTextBox)
        Controls.Add(progressStatusStrip)
        Controls.Add(flp)
        backgroundWorker = New BackgroundWorker()
        backgroundWorker.WorkerReportsProgress = True
        AddHandler backgroundWorker.DoWork, AddressOf backgroundWorker1_DoWork
        AddHandler backgroundWorker.RunWorkerCompleted, AddressOf backgroundWorker1_RunWorkerCompleted
        AddHandler backgroundWorker.ProgressChanged, AddressOf backgroundWorker1_ProgressChanged
    Private Sub backgroundWorker1_DoWork(sender As Object, e As DoWorkEventArgs)
        ' This method will run on a thread other than the UI thread.
        ' Be sure not to manipulate any Windows Forms controls created
        ' on the UI thread from this method.
        backgroundWorker.ReportProgress(0, "Working...")
        Dim lastlast As [Decimal] = 0
        Dim last As [Decimal] = 1
        Dim current As [Decimal]
        If requestedCount >= 1 Then
            AppendNumber(0)
        End If
        If requestedCount >= 2 Then
            AppendNumber(1)
        End If
        Dim i As Integer
        While i < requestedCount
            ' Calculate the number.
            current = lastlast + last
            ' Introduce some delay to simulate a more complicated calculation.
            System.Threading.Thread.Sleep(100)
            AppendNumber(current)
            backgroundWorker.ReportProgress(100 * i / requestedCount, "Working...")
            ' Get ready for the next iteration.
            lastlast = last
            last = current
            i += 1
        End While
        backgroundWorker.ReportProgress(100, "Complete!")
    Delegate Sub AppendNumberDelegate(number As [Decimal])
    Private Sub AppendNumber(number As [Decimal])
        If outputTextBox.InvokeRequired Then
            outputTextBox.Invoke(New AppendNumberDelegate(AddressOf AppendNumber), number)
        Else
            outputTextBox.AppendText((number.ToString("N0") + Environment.NewLine))
        End If
    Private Sub backgroundWorker1_ProgressChanged(sender As Object, e As ProgressChangedEventArgs)
        toolStripProgressBar.Value = e.ProgressPercentage
        toolStripStatusLabel.Text = e.UserState '
    Private Sub backgroundWorker1_RunWorkerCompleted(sender As Object, e As RunWorkerCompletedEventArgs)
        If TypeOf e.Error Is OverflowException Then
            outputTextBox.AppendText((Environment.NewLine + "**OVERFLOW ERROR, number is too large to be represented by the decimal data type**"))
        End If
        requestedCountControl.Enabled = True
        goButton.Enabled = True
    Private Sub button1_Click(sender As Object, e As EventArgs)
        goButton.Enabled = False
        toolStripProgressBar.Enabled = True
        requestedCount = Fix(requestedCountControl.Value)
        requestedCountControl.Enabled = False
        outputTextBox.Clear()
        backgroundWorker.RunWorkerAsync()
End Class
now i'm searching how to launch the progress meter  at the same time as my application start and not after
or exactly how to fix the max of the progressmeter to the end of dll's load
thank you
samideqlqpart
« Reply #20 on: August 11, 2017, 10:22:14 AM »
my big problem is
HOW TO SET THE MAX OF PROGRESS BAR?
Who it's corresponding to the  apparition of my drawing
trannks
samideqlqpart
« Reply #21 on: August 12, 2017, 07:07:32 AM »
or how to estimate the remaining time and display it.
samideqlqpart
« Reply #22 on: October 05, 2017, 07:07:23 AM »
hi
How to fill or to keep users waiting?
from the moment the user specifies the insertion point until when the code finishes the drawing.
with message or progressbar..
as this moment how to set the "setlimit"
thanks
« Reply #23 on: October 06, 2017, 04:49:55 AM »
Some nice elevator music?
<iframe width="854" height="480" src="https://www.youtube.com/embed/jj0ChLVTpaA" frameborder="0" allowfullscreen></iframe>
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #24 on: October 06, 2017, 05:13:56 AM »
Called Kerry in my other life
I live at UTC + 13.00
samideqlqpart
« Reply #25 on: October 09, 2017, 04:59:51 AM »
yeah
not bad idea!!!!!!
