Author Topic: Basic question relating "methods" (Active X)  (Read 998 times)
Peter2
« on: July 27, 2017, 03:05:18 AM »
Dumping an AECC_Sample_Line I get this results:
AECC_SAMPLE_LINE
; IAeccSampleLine: IAeccSampleLine-Schnittstelle
; Eigenschaftswerte:
;   Application (RO) = #<VLA-OBJECT IAeccApplication 0000021ee894f890>
;   Description = ""
; Unterstützte Methoden:
;   ArrayPolar (3)
;   IntersectWith (2)
I could not find any information about the IntersectWith-method for AECC_Sample_Line, but there is the "common" function "vla-IntersectWith". Based on this example my question is:
Are methods always "common" and supported by some /many / all objects, or are they depending on the particular object (so "vla-intersect" is not the same as "AECC_Sample_Line IntersectWith")??
Thanks for basic lessons ;-)
Peter
BricsCAD V23
dgorsman
Re: Basic question relating "methods" (Active X)
« Reply #1 on: July 27, 2017, 10:16:00 AM »
The AEC stuff is derived from base AutoCAD objects, and inherits a number of common properties and methods.  They don't always apply though, so you need the API help for both an object map and details on each.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
