Author Topic: Use of multiple loops in one routine?  (Read 1386 times)
Hrishikesh
« on: July 26, 2017, 09:32:37 AM »
Is it possible to use one loop multiple times in same loop? Or more than one loop under another loop?
example
1.
(repeat
(repeat
2.
(foreach
(foreach
(foreach
3.
(repeat
(foreach
Thanks,
Hrishikesh
ChrisCarlson
Re: Use of multiple loops in one routine?
« Reply #1 on: July 26, 2017, 10:09:14 AM »
In round about ways you can, the question would be why?
Hrishikesh
« Reply #2 on: July 26, 2017, 12:33:58 PM »
Today I am doing some Automation in Excel, looping some functions in one formula to obtain results.
I know Excel & Autolisp has different platforms for different purposes but I am just curious that can it be possible in autolisp & how?
Becase excel vba or excel itself has different syntex than autolisp.
Just a curiosity...
« Reply #3 on: July 26, 2017, 12:45:35 PM »
Certainly possible: since the expression argument for each of these looping functions is arbitrary, it may of course itself be an expression evaluating another looping function, e.g.:
  1. _$ (foreach x '("a" "b" "c" "d") (foreach y '(1 2 3) (print x) (princ y)))
  2.
  3. "a" 1
  4. "a" 2
  5. "a" 3
  6. "b" 1
  7. "b" 2
  8. "b" 3
  9. "c" 1
  10. "c" 2
  11. "c" 3
  12. "d" 1
  13. "d" 2
  14. "d" 3
As a more practical example, consider the following program which uses a nested repeat expression to iterate over every cell in a selected AutoCAD table:
  1. (defun c:test ( / col obj row sel )
  2.     (if (setq sel (ssget "_+.:E:S:L" '((0 . "ACAD_TABLE"))))
  3.         (progn
  4.             (setq obj (vlax-ename->vla-object (ssname sel 0)))
  5.             (repeat (setq col (vla-get-columns obj))
  6.                 (repeat (setq col (1- col) row (vla-get-rows obj))
  7.                     (vla-settext obj (setq row (1- row)) col (strcat "R" (itoa row) "C" (itoa col)))
  8.                 )
  9.             )
  10.         )
  11.     )
  12.     (princ)
  13. )
Hrishikesh
« Reply #4 on: July 26, 2017, 01:28:37 PM »
Thanks Lee  :-)
