When I generate HTML reports, I usually provide the option to write XML as well (fairly simple, as the former is derived from the latter). That way if the raw data is required it's more easily accessed.
But if you aren't generating the HTML yourself, pray that it's well formed. You can MSXML6 in LISP to read it as XML.
