Author Topic: FAS file not created???  (Read 2711 times)
Hrishikesh
« on: July 24, 2017, 09:27:08 AM »
I am using AutoCAD 2014 on windows-7,
When I tried to compile my lisp by using make application wizard .prv & .vlx files are created in folder but not FAS file?
I dont know is it due to windows-7 or Antivirus?
Is there any other options to compile lisp & create FAS file too?
Thanks,
Hrishikesh
irneb
Re: FAS file not created???
« Reply #1 on: July 24, 2017, 10:25:58 AM »
AFAIK the VLIDE's compile wizard only creates VLX files directly, no intermediate FAS files.
If you want a FAS file, then use the vlist-compile function in the VLIDE's console (or on an ACad command-line).
Hrishikesh
« Reply #2 on: July 24, 2017, 11:49:42 AM »
But when I load vlx file it will not run routine, AutoCAD shows invalid command error message.
CincyJeff
« Reply #3 on: July 24, 2017, 12:30:59 PM »
When I compile from .prv in the editor I get a .fas file for each .lsp file included. Are you able to use (vlisp-compile 'st "Drive:/Path/File") to get a .fas? If not, you probably have an error in the .lsp file.
ChrisCarlson
« Reply #4 on: July 24, 2017, 01:53:22 PM »
Does your lisp routine run correctly? I could be wrong, but I do not think a .fas is created when you output to a .vlx.
VovKa
  • Ukraine
« Reply #5 on: July 24, 2017, 04:08:10 PM »
.fas is always created along with the .vlx
Hrishikesh
« Reply #6 on: July 24, 2017, 11:53:10 PM »
I asked system administrator in my office for the same. He told me that antivirus installed has treated .fas as malware so it doesn't show in folder in which compiler creates supporting files of .vlx or .prv.
MeasureUp
« Reply #7 on: July 25, 2017, 03:02:24 AM »
Do you mind to tell what AV software is?
BTW
M_S & VovKa are right.
VLIDE creates VLX, FAS & PRV files all time, when I compile LSP.
Hrishikesh
« Reply #8 on: July 25, 2017, 10:56:44 AM »
AV-Mcafee
Windows 7
AutoCAD 2014
Hrishikesh
« Reply #9 on: July 26, 2017, 01:50:00 AM »
I tried to create using vlisp-compile but no .fas file created at given path.
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #10 on: July 26, 2017, 03:36:35 AM »
Is this the first time you have done this process ? If so, it is more likely to be a procedural error.
Exactly how are you doing it ?
I assume the program runs prior to compiling ?
Are you using Separate namespace ?
You may need to provide snapshots of your dialogs.
Regards,
added
Does your compile statement look something like this
  1. ;|
  2. (vlisp-compile
  3.   'st
  4.   "L:/Projects-VisualLisp-2017/SD210/Tools/KDUB_NewUcs.lsp"
  5.   "L:/Projects-VisualLisp-2017/FAS/KDUB_NewUcs"
  6. )
  7. |;
  8.
« Last Edit: July 26, 2017, 03:40:23 AM by kdub »
Called Kerry in my other life
I live at UTC + 13.00
Hrishikesh
« Reply #11 on: July 26, 2017, 08:40:54 AM »
Regards,
added
  1. ;|
  2. (vlisp-compile
  3.   'st
  6. )
  7. |;
  8.
I have attached screenshots of procedure which i follow to make .fas
In last screenshot you can see list of files after compilation, no .fas file in list.
CincyJeff
« Reply #12 on: July 26, 2017, 12:10:29 PM »
Is it possible Windows is hiding the .fas file type?
Have you tried just creating the .fas file?
(vlisp-compile 'st "D:/LSP/XH")
Hrishikesh
« Reply #13 on: July 26, 2017, 12:25:20 PM »
I tried to make fas file from vlisp-compile but result is same no fas file shows in folder even show all file option in widows is on. May be its a Antivirus which prevents creating fas file.
