Author Topic: How many Pendrive  (Read 1061 times)
josan
  • Mosquito
How many Pendrive
« on: July 23, 2017, 03:34:45 PM »
I want to know through lisp how many pendrive are connected to the pc.
To go through each one and read its physical direction.
Is this possible with lisp?
thanks...
PKENEWELL
Re: How many Pendrive
« Reply #1 on: July 26, 2017, 03:45:16 PM »
The Answer is: Not exactly...
Using the (vlax-create-object "Scripting.FileSystemObject") you can get the property "DriveType". A return value of 1 means the Drive is a "Removable" drive. However - there are more things than stick drives that will come up with that designation. Anything that holds storage, such as a phone or an SD drive will also return this value.
"When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it." - Theodore Roosevelt
