The Answer is: Not exactly...
Using the (vlax-create-object "Scripting.FileSystemObject") you can get the property "DriveType". A return value of 1 means the Drive is a "Removable" drive. However - there are more things than stick drives that will come up with that designation. Anything that holds storage, such as a phone or an SD drive will also return this value.
