Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Problem Mtext color is not changing by Auto lisp???
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Problem Mtext color is not changing by Auto lisp??? (Read 1512 times)
Hrishikesh
Guest
on:
July 13, 2017, 10:47:06 AM »
Hi All,
I am facing a small problem regarding changing color of mtext.
If the mtext color is set from mtext editor, Autolisp is not changing color of that particular mtext.
Can anybody help me on this issue?
Screenshot & Lisp is attached.
Code - Auto/Visual Lisp:
[Select]
vl-load-com
defun
C:Change_Mtext_Color
en
setq
en
car
entsel
\n
Select Mtext"
setq
en
vlax
ename
vla-object
en
if
"AcDbMText"
vla-get-objectname
en
vla-put-color
en
2
;_ end of if
;_ end of defun
defun
C:Change_Mtext_Color1
en
setq
en
car
entsel
\n
Select Mtext"
setq
elist
entget
en
setq
elist
subst
cons
62
2
assoc
62
elist
elist
entmod
elist
entupd
en
;_ end of defun
Logged
Needs a day job
Re: Problem Mtext color is not changing by Auto lisp???
Reply #1 on:
July 13, 2017, 11:13:56 AM »
Do a search for 'stripmtext'.
Logged
Global Moderator
Seagull
Reply #2 on:
July 13, 2017, 01:21:07 PM »
Got my trusty index handy.
-------------- Strip MText ----------------
https://www.theswamp.org/index.php?topic=31584.0
https://www.theswamp.org/index.php?topic=17185.0
https://www.theswamp.org/index.php?topic=14764.0
Logged
Hrishikesh
Guest
Reply #3 on:
July 13, 2017, 02:39:57 PM »
Hey Thanks!!!
This not only solve my problem but it' other options will help me a lot in my daily work also.
Now I have a powerful weapon to deal with "MTEXT"
Thanks Again...
-Hrishikesh
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
