CAD Forums > CAD General
identify parallel lines
MSTG007:
Any way to identify from a selection of lines or polylines which ones are parallel to the one you select? I really do not feel like redrawing something if I already know which ones are ok. Thanks for the help!
CAB:
Lots of info on this site.
http://www.theswamp.org/index.php?topic=23170.msg281630#msg281630
MSTG007:
Thanks CAB, ill check it out.
dgorsman:
If the lines are reduced to unit vectors they should be directly comparable (with a bit of fuzz).
MSTG007:
I kind of had to redraw it. But this is what I was looking at. We received an site plan from the architect. I wanted to make sure that the parking stalls were parallel with the building. So by selecting a line it would then high light all the lines that are parallel with it.
Navigation
[0] Message Index
[#] Next page
Go to full version
