Author Topic: Retrieve the last command call  (Read 3134 times)
Grrr1337
« on: July 01, 2017, 08:57:04 AM »
Hi everyone,
Is there a way to obtain the last called command ?
I tried with command reactor, but its successful only with the standard commands, not the lisp defined.
Or maybe theres a variable I'm not aware about?
My intention is to wire it with a mouse reactor (so when double-clicking somewhere [and not on any object, (nentselp) = nil ] it will reinvoke the last command).
Just like hitting space behavoiur, but using the mouse only.
The reason is that I'm tired to reach the keyboard, while lying on my comfy couch and looping [SPACE] key, selecting and pressing [RMB] .  :yawn:
So I'm trying to translate this loop to: [LMB] double-click, selecting and pressing [RMB] (which requires only the mouse).
(apply ''((a b c)(a b c))
vevo.bg
Re: Retrieve the last command call
« Reply #1 on: July 01, 2017, 09:08:58 AM »
Maybe something like this?
  1. (defun dblclk:enable ( key )
  2.     (dblclk:remove key)
  3.         (vlr-mouse-reactor key '((:vlr-begindoubleclick . dblclk:callback)))
  4.         'active-document-only
  5.     )
  6.         (vlr-dwg-reactor key '((:vlr-beginclose . dblclk:release)))
  7.         'active-document-only
  8.     )
  9. )
  10. (defun dblclk:remove ( key )
  11.         (foreach rtr (cdr grp)
  12.             (if (= key (vlr-data rtr)) (vlr-remove rtr))
  13.         )
  14.     )
  15.     (if (and (= 'vla-object (type dblclk:wsh:object)) (not (vlax-object-released-p dblclk:wsh:object)))
  16.         (progn
  17.             (vlax-release-object dblclk:wsh:object)
  18.             (setq dblclk:wsh:object nil)
  19.         )
  20.     )
  21. )
  22. (defun dblclk:callback ( rtr arg )
  23.     (vl-catch-all-apply 'vlax-invoke (list (dblclk:wsh) 'sendkeys "{ESC}{UP}~"))
  24.     (princ)
  25. )
  26. (defun dblclk:release ( rtr arg )
  27.     (dblclk:remove "dblclk:reactor")
  28. )
  29. (defun dblclk:wsh ( )
  30.     (cond (dblclk:wsh:object) ((setq dblclk:wsh:object (vlax-create-object "wscript.shell"))))
  31. )
  32. (   (lambda ( )
  33.         (vl-load-com)
  34.         (dblclk:enable "dblclk:reactor")
  35.         (princ)
  36.     )
  37. )
But why not simply enable right-click enter?
« Last Edit: July 01, 2017, 09:12:00 AM by Lee Mac »
Grrr1337
« Reply #2 on: July 01, 2017, 09:42:25 AM »
Ahh, SendKeys - I've forgot about this! :)
Thats a second option, haven't thought about it - although my suggested double-click LMB approach would be lazier.
Thank you Lee, I wasn't expecting a whole code reactor - but just an advice how to obtain that same last command.
Even your reply was super fast, like you coded it instantly, inside the quick reply post. :D
I guess it would be better to include this check to the callback function:
  1. (defun dblclk:callback ( rtr arg )
  2.   (and
  3.     (null (nentselp (car arg)))
  4.     (vl-catch-all-apply 'vlax-invoke (list (dblclk:wsh) 'sendkeys "{ESC}{UP}~"))
  5.   )
  6.   (princ)
  7. )
  8.
Since doublecliking on polylines, AutoCAD invokes some other reactor that prompts with getkword (the "PEDIT" command)
You could patent it as "Lazy Reactor" under your name! :)
vevo.bg
VovKa
  • Ukraine
« Reply #3 on: July 01, 2017, 01:16:49 PM »
i doubt that
(double-click LMB + programming) is no way lazier than (single click RMB + no programming)
Grrr1337
« Reply #4 on: July 02, 2017, 03:13:58 AM »
i doubt that
You are right Vovka (I was wrong again), however I remembered why I purposely disabled my right click enter option - because I was using this "isolateobjects" tool.
Ofcourse theres the ribbon also, but I hate using it and I always keep it hidden (to work on a larger viewport size).
I remember that someone wrote this:
Every AutoCAD user works differently than the other.
vevo.bg
« Reply #5 on: July 02, 2017, 09:29:23 AM »
But you can have both - just do a long right-click to open the shortcut menu.
Grrr1337
« Reply #6 on: July 02, 2017, 04:45:48 PM »
I wasn't aware of this!
Thank you so much, Lee - I still appreciate the reactor solution you provided !
vevo.bg
