Author Topic: Double comparison  (Read 1759 times)
latour_g
Double comparison
« on: June 29, 2017, 09:57:28 AM »
I would like to sort a list base on two values.  Is it possible to add another compare in my class BlkFleche ?
I need the list to be sort base on the X and then base on the Y, those are from coordinates.
So if I have my X and Y like that :
[10,1]
[4,6]
[9,2]
[10,4]
[4,2]
[10,6]
I would like the end result to be :
[4,2]
[4,6]
[9,2]
[10,1]
[10,4]
[10,6]
I'm using a list because I need to keep data in relation with the coordinates.
Code - C#: [Select]
  1. public class blkFleche : IComparable<blkFleche>
  2. {
  3.     public double positionX { get; set; }
  4.     public double positionY { get; set; }
  5.     public string attNOCABLE { get; set; }
  6.     public string attNOFIBRE { get; set; }
  7.
  8.     public int CompareTo(blkFleche other)
  9.     {
  10.         return this.positionX.CompareTo(other.positionX);
  11.     }
  12. }
  13.
  14. private void btnRead()
  15. {
  16.       List<blkFleche> listBlkSort = new List<blkFleche>();
  17.       //...
  18.       blkFleche blkNew = new blkFleche();
  19.       //...
  20.       blkNew.positionX = blkRef.Position.X;
  21.       blkNew.positionY = blkRef.Position.Y;
  22.       //...
  23.       listBlkSort.Add(blkNew);
  24.       //...
  25.       listBlkSort.Sort();
  26. }
Re: Double comparison
« Reply #1 on: June 29, 2017, 10:11:27 AM »
I might have a chance later to create an example, but LINQ has ThenBy that you could use.
https://msdn.microsoft.com/en-us/library/bb534743(v=vs.110).aspx
gile
  • Marseille, France
« Reply #2 on: June 29, 2017, 10:57:53 AM »
You can implement IComparable<blkFleche> this way:
Code - C#: [Select]
  2.     {
  7.
  9.         {
  10.             int compareX = this.positionX.CompareTo(other.positionX);
  11.             return compareX == 0 ? this.positionY.CompareTo(other.positionY) : compareX;
  12.         }
  13.     }
But as Jeff said, you can directly use linq extension methods:
Code - C#: [Select]
  1. List<blkFleche> listBlk = new List<blkFleche>();
  2.
  3. // fill the listBlk
  4.
  5. List<blkFleche> listBlkSort = listBlk
  6.     .OrderBy(blk => blk.positionX)
  7.     .ThenBy(blk => blk.positionY)
  8.     .ToList();
Or, more efficiently, if you do not absolutely need a List<blkFleche>:
Code - C#: [Select]
  1. IEnumerable<blkFleche> listBlkSort = listBlk
  2.     .OrderBy(blk => blk.positionX)
  3.     .ThenBy(blk => blk.positionY);
latour_g
« Reply #3 on: June 29, 2017, 04:14:42 PM »
Great, thank you both !
