Author Topic: Batch change plot style table lisp not working  (Read 1523 times)
tive29
« on: June 24, 2017, 10:47:17 PM »
http://www.theswamp.org/index.php?topic=42694.msg478856#msg478856
I got the lisp code from the above link by ronjonp but it is not working for me.
I need to change a batch of drawings from ""NONE to "MyplotStyle.ctb"
This is the edited lisp
Why is it not working?
    (defun c:changepc3
           (/ _openfile _subfolders _getdirectory dir doc folders l logfile new odbx old save v)
      ;; Change this value - ie. { "*" or "\\\\servername\\oldsharedprintername" }
      (setq old "*)
      ;; Change this value - ie. { "MyplotStyle.ctb" or "\\\\servername\\newsharedprintername" }
      (setq new "MyplotStyle.ctb")
      (defun _openfile (file / sh)
        (if (findfile file)
          (progn (setq sh (vlax-get-or-create-object "Shell.Application"))
         (vlax-invoke-method sh 'open (findfile file))
         (vlax-release-object sh)
         file
      (defun _getdirectory (message / sh folder result)
        (setq folder (vlax-invoke-method sh 'browseforfolder 0 message 0))
        (if folder
          (progn (setq result (vlax-get-property (vlax-get-property folder 'self) 'path))
         (if (/= (substr result (strlen result)) "\\")
           (setq result (strcat result "\\"))
           result
      (defun _subfolders (path / folder fs lst subs)
        (setq fs (vlax-get-or-create-object "Scripting.FileSystemObject"))
          (and (setq folder (vlax-invoke fs 'getfolder path)) (setq subs (vlax-get folder 'subfolders)))
           (mapcar (function (lambda (x) (cons x (apply 'append (_subfolders x)))))
           (vlax-for sub subs (setq lst (cons (strcat (vlax-get sub 'path) "\\") lst)))
      (setq doc (vlax-get-acad-object))
        ((not (setq odbx (if (< (setq v (substr (getvar 'acadver) 1 2)) "16")
           (vla-getinterfaceobject doc "ObjectDBX.AxDbDocument")
           (vla-getinterfaceobject doc (strcat "ObjectDBX.AxDbDocument." v))
         (princ "\nObject DBX interface not created!")
        ((if (and (setq dir (_getdirectory "Choose a folder to process (subfolders processed too)..."))
          (and (setq folders (apply 'append (_subfolders dir)))
       (setq folders (append (list dir) folders))
          (setq logfile (open (setq l (strcat dir "logfile.csv")) "w"))
    (write-line "FILE,TABS UPDATED,SAVED" logfile)
    (foreach folder folders
       (foreach file (vl-directory-files folder "*.dwg" 0)
         (if (vl-catch-all-error-p
       (vl-catch-all-apply 'vla-open (list odbx (strcat folder file)))
           (write-line (strcase (strcat "!!Error opening: " (strcat folder file))) logfile)
    (setq save 0)
    (vlax-for x (vla-get-layouts odbx)
       (if (wcmatch (strcase (vla-get-configname x)) (strcase old))
         (progn (and (not (vl-catch-all-error-p
    (vl-catch-all-apply 'vla-put-configname (list x new))
    (setq save (1+ save))
    (if (zerop save)
       (write-line (strcat (strcat folder file "," (itoa save) ",NO")) logfile)
       (progn (write-line (strcat (strcat folder file "," (itoa save) ",YES")) logfile)
      (vla-saveas odbx (vla-get-name odbx))
    (close logfile)
    (_openfile l)
roy_043
  • BricsCAD 18
Re: Batch change plot style table lisp not working
« Reply #1 on: June 25, 2017, 04:24:07 AM »
This stands out:
(setq old "*)Should be :
(setq old "*")
