CAD Forums > CAD General
Select Similar Hatch for Gross Area
MSTG007:
I was looking if there is a easy way to get the gross areas of these hatches if I select similar. I am not having any luck.
I know the long way of doing it with Re-associating a boundary with it on each one and then delete the hatch. . .
Is there a routine that I could select all of them and converts them over to a hatch that gives me the area with the same source hatch pattern? Just brainstorming around.
Thanks for any ideas.
Rob...:
That sounds like something Lee Mac would have.
ronjonp:
I've been using THIS for years.
cadtag:
FILTER will let you select by Hatch Pattern Name. Note that it is case-sensitive
ronjonp:
This will place boundaries on a layer named the same as the pattern name. Then you can tally the areas by layer name.
--- Code - Auto/Visual Lisp: ---(defun c:hbound (/ *error* i p s v x) (defun *error* (msg) (mapcar '(lambda (x) (setvar (car x) (cdr x))) v) (if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")) (princ (strcat "\nError: " msg)) ) (princ) ) (setq i 0) ;; Tested in AutoCAD 2018 - RJP 6.20.2018 ;; Creates boundaries on layers that match the hatch pattern name (if (setq s (ssget '((0 . "hatch")))) (progn (setq v (mapcar '(lambda (x) (cons x (getvar x))) '("clayer" "cmdecho" "hpseparate" "hpbound")) ) (setvar 'cmdecho 0) (setvar 'hpseparate 1) (setvar 'hpbound 1) (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (if (null (tblobjname "layer" (setq p (cdr (assoc 2 (entget x)))))) (entmakex (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") '(70 . 0) (cons 2 p) '(6 . "Continuous") (cons 62 (setq i (1+ i))) ) ) ) (setvar 'clayer p) (command "_hatchgenerateboundary" x "") ) (mapcar '(lambda (x) (setvar (car x) (cdr x))) v) ) ) (princ))
Navigation
[0] Message Index
[#] Next page
Go to full version
