Author Topic: To share or not to share!  (Read 2232 times)
« on: June 11, 2017, 08:40:02 AM »
There seems to be some debate amongst the interwebs regarding shared/static functions and if/when you should do so.
My question is directly related to exposed commands in AutoCAD as is evidenced by the following code snippets:
Code - vb.net: [Select]
  1. <CommandMethod("MyCommand", CommandFlags.Modal)>
  2. Public Shared Sub MyCommand()
  3.         MyClass.SharedSub()
  4. End Sub
Code - C#: [Select]
  1. [CommandMethod("MyCommand", CommandFlags.Modal)]
  2. public static void MyCommand()
  3. {
  4.     MyClass.StaticSub();
  5. }
What are the advantages of declaring these static and are there issues if they are not?
Keith Brown
Re: To share or not to share!
« Reply #1 on: June 11, 2017, 11:14:03 AM »
Norman has written a nice article about this question several years ago.
http://drive-cad-with-code.blogspot.com/2010/09/command-method-static-or-not-static.html
« Reply #2 on: June 11, 2017, 10:40:08 PM »
I was aware of what he talks about ... I guess it doesn't really matter unless I need to move data between drawings. The application I am working on only works on the current document and doesn't need to be MDI aware.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #3 on: June 12, 2017, 12:17:34 AM »
Static will be slightly faster, not something a user would notice though... Instance offers more flexibility, so I’d probably prefer the later.
However, I’d probably prefer static lisp functions
« Reply #4 on: June 12, 2017, 01:07:54 AM »
I have multiple commands that are exposed. All of them are used to instantiate a specific class or call static code directly.
