Author Topic: QGIS dxf export labeling points  (Read 4306 times)
dubb
« on: June 09, 2017, 05:10:05 PM »
If anyone here uses QGIS. Have you tried exporting points to a .dxf file? I cannot seem to get the labels along with the points. What I get is points on a layer named as the label. Also, is there any other csv to dxf conversion tool that anyone would recommend?
Re: QGIS dxf export labeling points
« Reply #1 on: August 24, 2017, 03:49:26 PM »
when using QGIS, I would suggest export the points to CSV from C3D
then in QGIS  there is an Add Layer from delimited text function to place the points in your QGIS project.
IF you are taking points from QGIS to C3D, then I suggest export to SHP file instead, the attributes will come along for the ride.
