Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
LISP HELP - Combine functions into single COMMAND
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: LISP HELP - Combine functions into single COMMAND (Read 1455 times)
aswin
Mosquito
on:
June 07, 2017, 01:07:14 AM »
Hi friends .. I am posting a lisp here... this lisp functions are 'CURRENT LAYOUT SETUP TO ALL LAYOUT TABS' and 'PRINT ALL LAYOUTS TABS' .
but i have to enter two comments ,
CPS='CURRENT LAYOUT SETUP TO ALL LAYOUT TABS'
PT ='PRINT ALL LAYOUTS TABS'
can we make this into a single command for both functions?
Code - Auto/Visual Lisp:
[Select]
;; Copy current layout page setup to all layout tabs
vl-load-com
defun
c:CPS
Adoc Layts clyt
setq
aDoc
vla-get-activedocument
vlax-get-acad-object
Layts
vla-get-layouts
aDoc
clyt
vla-get-activelayout
aDoc
foreach
itm
vl-remove
vla-get-name
clyt
layoutlist
vla-copyfrom
vla-item
Layts itm
clyt
princ
Defun
C:PT
PLO_LAYOUTS PLO_CNTR PLO_LIST PLO_LAYOUTTAB
vl-load-com
setvar
"FILEDIA"
0
setvar
"CMDDIA"
0
initget
6
; disallow 0 or <0
setq
nofs
getint
"Enter number of sets: <1>"
setq
nofs
if
or
nofs
nofs
0
nofs
1
setq
PLO_LAYOUTS
vla-get-layouts
vlax-for
PLO_LAYOUT PLO_LAYOUTS
setq
plo_list
cons
vla-get-name
PLO_LAYOUT
plo_list
setq
PLO_LIST
reverse
PLO_LIST
while
nofs
1
setq
plo_cntr
0
repeat
1-
length
plo_list
; plot all but MODEL
setq
PLO_LAYOUTTAB
nth
PLO_CNTR PLO_LIST
command
"-PLOT"
"n"
PLO_LAYOUTTAB
setq
PLO_CNTR
1+
PLO_CNTR
prompt
\n
Plot Set Complete"
setq
nofs
1-
nofs
setvar
"FILEDIA"
1
setvar
"CMDDIA"
1
princ
Edit kdub : changed Subject title to be descriptive.
add code tags
Last Edit: June 07, 2017, 04:02:32 AM by kdub
Logged
Abu Dhabi
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
class keyThumper<T>:ILazy<T>
Re: LISP HELP - Combine functions into single COMMAND
Reply #1 on:
June 07, 2017, 04:54:52 AM »
You could try something like :
[Select]
defun
c:CPS
PT
c:CPS
c:PT
princ
Logged
Called Kerry in my other life
I live at UTC + 13.00
aswin
Mosquito
Reply #2 on:
June 07, 2017, 05:02:16 AM »
@kdub
thank you soo much...
Logged
Abu Dhabi
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
