Author Topic: Sloped corridors..  (Read 179 times)
hudster
Sloped corridors..
« on: June 02, 2017, 04:00:16 am »
We are working on a public space, and it has lots of transitional corridors many over 100 meters long, and all of them slope.
The slopes on a short corridor are ok, but some of these ones due to length, slope down 2 levels.
What we did was to create many smaller levels at 250mm increments and show 20 meter long sections of the corridors, but I don't think it was perhaps the best way to go about this.
So how would you go about creating multiple views efficiently?
lamarn
Re: Sloped corridors..
« Reply #1 on: June 02, 2017, 08:10:46 am »
To me this sounds like your posting on the wrong forum section. Use Revit for buildings. Corridors, slopes, public space, Gis?.. It sounds infra to me. Revit no go.
hudster
« Reply #2 on: June 02, 2017, 10:17:00 am »
It's an internal space in a public building, they are all internal corridors, just over huge distances.
Matt__W
  • I like my water diluted.
« Reply #3 on: June 03, 2017, 02:03:26 pm »
Ramps???
Autodesk Expert Elite
Autodesk Revit Architecture, Structure, MEP Mechanical and MEP Electrical Certified Professional
Building Performance Analysis Certified (BPAC v3.0)
Autodesk Navisworks 2014 Essentials
42
« Reply #4 on: June 05, 2017, 07:58:07 am »
Ramps yes. I would set the start of the ramp at a given level, then offset the finish at level plus 500mm for instance. This would give a 1/20 slope and the max rise allowed. Start the next ramp at level plus 500mm and finish at level plus 1000mm and so on and so forth. Not forgetting the level platforms between each ramp.
Alastair Mallett Autodesk Certified Professional
Technical Director
Hunters South Architects
