Author Topic: How to determine whether an object has an property?  (Read 2632 times)
gswang
« on: June 01, 2017, 11:48:12 PM »
In .NET,How to determine whether an object has an property? like vlax-property-available-p in lisp.
(vlax-property-available-p obj 'Thickness)
Thank you very much!
« Last Edit: June 02, 2017, 12:45:07 AM by gswang »
Atook
  • AKA Tim
Re: How to determine whether an object has an attribute?
« Reply #1 on: June 02, 2017, 12:09:47 AM »
From Autodesk.
You can check the BlockTableRecord for .HasAttributes.
If so, you can access them via the blockreference.AttributeCollection.
« Last Edit: June 02, 2017, 02:13:58 AM by Atook »
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: How to determine whether an object has an property?
« Reply #2 on: June 02, 2017, 12:37:19 AM »
Since attribute are attached to blocks ...
Called Kerry in my other life
I live at UTC + 13.00
gile
  • Marseille, France
« Reply #3 on: June 02, 2017, 01:25:26 AM »
You can use Reflection:
Code - C#: [Select]
  1. public bool IsAvailableProperty(object obj, string propertyName) =>
  2.     obj.GetType().GetProperties().Any(p => p.Name == propertyName);
« Last Edit: June 02, 2017, 01:42:56 AM by gile »
gswang
« Reply #4 on: June 02, 2017, 08:13:05 AM »
Thank you, gile,
but i can't compile successfully, how to use reflection?
gile
  • Marseille, France
« Reply #5 on: June 02, 2017, 08:32:42 AM »
You have to add a using System.Linq; directive and, if you're not using VS 2015 ou higher (C# 6), change the code as this:
Code - C#: [Select]
  2.         {
  3.             return obj.GetType().GetProperties().Any(p => p.Name == propertyName);
  4.         }
gswang
« Reply #6 on: June 02, 2017, 09:02:01 AM »
Thank you very much, gile. I made it successfully! :2funny:
Bobby C. Jones
  • Cry havoc and let loose the dogs of war.
« Reply #7 on: June 05, 2017, 04:08:11 PM »
Nothing against reflection, it can be useful, but it seems in a type safe environment the better question asks if the object implements an interface that declares the desired property or method.
Bobby C. Jones
