Author Topic: Civil3D - Contour - Multiple Labels  (Read 2550 times)
MSTG007
« on: May 30, 2017, 09:47:48 AM »
I did not know if someone might have another work around. Looking for a way that I can draw a polyline and then convert that to a Contour - Multiple Label Style. But what would be way cool is to be able to add vertex's along existing Contour - Multiple Label Lines.
Thanks for any ideas on this.
Civil3D 2020
Re: Civil3D - Contour - Multiple Labels
« Reply #1 on: August 24, 2017, 03:52:27 PM »
that would be cool, but NO....there is nothing for that
BIGAL
  • 40 + years of using Autocad
« Reply #2 on: August 25, 2017, 05:10:15 AM »
It says you ahve CIV3D, If you draw a pline using the Elevation set to the required z then explode it you can add the lines to the surface model using the objects option within Surfaces.
