Author Topic: Enclose Points with Polyline  (Read 2468 times)
cadplayer
« on: May 29, 2017, 01:25:00 PM »
Hello!
May somebody have a idea to create enclosed Polyline outside from Points in Drawing.
I have a Drawing with many  DbPoints. What I want to do is to create a Polyline which goes over all outer Points.
In Civil3d there is a command with lineworkshrinkwrap, where I can select a block and get a borderline from contours of block.
I would like do the same but not use with command with senttoexecute.
Thank you for inspiration!
gile
  • Marseille, France
Re: Enclose Points with Polyline
« Reply #1 on: May 29, 2017, 01:40:57 PM »
Have a look at the ConvexHull route.
cadplayer
« Reply #2 on: May 30, 2017, 01:19:57 PM »
Nice Gile, thank you for your work and sharing. Let me think about more - in my case is created Polyline not enclose overall.
gile
  • Marseille, France
« Reply #3 on: May 30, 2017, 02:32:52 PM »
So, did you try the TEST command n the provided link?
cadplayer
« Reply #4 on: June 01, 2017, 01:15:32 PM »
Sorry for delay Gile, yes I have test your function and it´s really nice your thought. I have to configure out a bit more, because it does not draw Polyline(yellow) overall.
http://www.screencast.com/t/DQPecCuwsB
Atook
  • AKA Tim
« Reply #5 on: June 01, 2017, 01:23:08 PM »
Good to see the example cadplayer. Is it possible that elevation is causing the dips in the convex hull/shrinkwrap?
cadplayer
« Reply #6 on: June 02, 2017, 07:41:27 AM »
My goal to draw outerline or enclosed Polylines is to set Boundary for calculate Triangulation. Giles example show´s to create 2dPolyline enclosed around selected Points, But I need more exactly line:
black line behind red triangle
http://s1356.photobucket.com/user/cadplayer/media/Triangulate_zps5egmsmru.png.html
Here is my example to get enclosed lines
        public static void ObjectsToEnclose(Entity acEnt)
            Document acDoc = Application.DocumentManager.MdiActiveDocument;
            string strHandle = acEnt.Handle.ToString();
            acDoc.SendStringToExecute("lineworkshrinkwrap ", true, false, false);
            string command = string.Format("(handent \"" + strHandle + "\") ");
            acDoc.SendStringToExecute(command, true, false, false);
Works only in Civil3d or MAP
« Last Edit: June 02, 2017, 07:47:40 AM by cadplayer »
