Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
Export from AutoCAD Map to ESRI 3d Shapefile
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Export from AutoCAD Map to ESRI 3d Shapefile (Read 1851 times)
manivanchi
Guest
on:
May 29, 2017, 02:33:15 AM »
Good Morning/Evening to all.
Can anyone help me to Export the shapes from AutoCAD Map to ESRI 3d Shapefiles.
Thanks & Regards,
Manikandan S V
Logged
Chris
Swamp Rat
Re: Export from AutoCAD Map to ESRI 3d Shapefile
Reply #1 on:
May 29, 2017, 10:48:42 PM »
The command MAPEXPORT should get you what you need. You choose an option for file type, select your objects and away you go.
Logged
Christopher T. Cowgill, P.E.
AEC Collection 2020 (C3D)
Win 10
manivanchi
Guest
Reply #2 on:
May 29, 2017, 11:57:20 PM »
Hi Chris,
Thanks for your reply.
I am unable get the 3d shapefile in mapexport. Please explain the procedure.
I need the Z value of each and every vertices of Line and Polygon should be stored in shapefile.
Thanks & Regards,
Manikandan Vanchinathan
Logged
huiz
Swamp Rat
Certified Prof C3D
Reply #3 on:
May 30, 2017, 01:49:38 AM »
In the Map Export dialog there is a tab called Options. There you find a button named Driver Options. If you click the button, a dialog appears where you can set the 2D or 3D export.
Logged
manivanchi
Guest
Reply #4 on:
May 30, 2017, 11:25:22 PM »
Thank You So Much
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
