Author Topic: Seeing Levels  (Read 653 times)
Rob...
Seeing Levels
« on: May 24, 2017, 02:28:00 pm »
I've got a project with levels that only correspond to parts of the building.
Is there a way to see the extent of the levels in a plan view?
CAD Tech
rvhwlc
Re: Seeing Levels
« Reply #1 on: May 24, 2017, 06:18:37 pm »
no section or elev only.. extents may be constrained by scope box..
Rob...
Re: Seeing Levels
« Reply #2 on: May 24, 2017, 07:27:45 pm »
That's not just a little bit disappointing. I'm guessing a 3D view is also out of the question.
CAD Tech
42
Re: Seeing Levels
« Reply #3 on: May 25, 2017, 08:01:57 am »
I presume that you want to see more of the building than what is just on that level? You can stretch the crop view box, or turn it off. To view levels below your current level either extend the view range or click on Underlay and chose a level to display.
A 3D view will show everything providing that its set to be seen in that view.
Alastair Mallett Autodesk Certified Professional
Technical Director
Hunters South Architects
Rob...
Re: Seeing Levels
« Reply #4 on: May 25, 2017, 09:11:36 am »
Actually, I'd like to see the level itself, not the stuff associated with it. Either in the form of a rectangle in a plan view or a plane in a 3D view.
CAD Tech
Matt__W
  • I like my water diluted.
Re: Seeing Levels
« Reply #5 on: May 25, 2017, 09:27:25 am »
Nope. Can't do that.
Autodesk Expert Elite
Autodesk Revit Architecture, Structure, MEP Mechanical and MEP Electrical Certified Professional
Building Performance Analysis Certified (BPAC v3.0)
Autodesk Navisworks 2014 Essentials
Krushert
  • "GRAMR? I need no stinkin' gramr!"
Re: Seeing Levels
« Reply #6 on: May 25, 2017, 09:45:11 am »
Revit Sucks!! as bad as Kmart does!
 :crazy2:
Don't ask me questions without answers.
Bobby C. Jones
  • Cry havoc and let loose the dogs of war.
Re: Seeing Levels
« Reply #7 on: May 25, 2017, 11:24:39 am »
You can set the level as your current workplane and then toggle visibility of the current workplane on.  It'll show in plan and 3D views.
Bobby C. Jones
Matt__W
Re: Seeing Levels
« Reply #8 on: May 25, 2017, 03:13:56 pm »
Wait... what??!?  Does it show the extent of the levels with regards to elevation views? Or is it just a partial representation? Either way, pretty cool. Never knew that was there.
Bobby C. Jones
Re: Seeing Levels
« Reply #9 on: May 25, 2017, 03:51:10 pm »
That's a great question, I don't know how it determines the extents when it initially shows.  It has grips at each edge that allow you to change it though.
Bobby C. Jones
Bobby C. Jones
Re: Seeing Levels
« Reply #10 on: May 25, 2017, 03:53:51 pm »
I suppose if it doesn't come in at the extents set in elevation view, then this isn't really much help to Rob :-/
Bobby C. Jones
Rob...
Re: Seeing Levels
« Reply #11 on: May 25, 2017, 03:59:02 pm »
Even if it doesn't show the extents, it will be at least somewhat helpful for this particular project. I can't wait to try it out. I'll check to see if it corresponds with the extents in section and post back my findings.
CAD Tech
Rob...
Re: Seeing Levels
« Reply #12 on: May 26, 2017, 07:29:19 am »
It does not show the extents of the levels.
CAD Tech
rvhwlc
Re: Seeing Levels
« Reply #13 on: May 26, 2017, 10:32:41 am »
i got ecxited for moment... wish it did..
Matt__W
Re: Seeing Levels
« Reply #14 on: May 26, 2017, 01:40:42 pm »
That's what she said....
