Author Topic: Link Circle's Radiuses - Using Object Reactor and ??? Reactor  (Read 3443 times)
Grrr1337
Hi guys,
I was wondering could someone help me to figure this out:
1. Initial settings: Select circles to link their radiuses - set default radius value of 50
2. Reactor's action: When One of the circle's radius is modified match the radiuses of the rest of the circles to the one we just modified
So my thinking logic is to:
1.Select few circles, apply to them the same radius, include them in a list as vla-objects
2.Include them in a Object reactor to be watched
3.In the callback check for every watched object's radius and activate ?X? reactor (I'm not sure what type) that will match the radiuses, then immediately remove the ?X? reactor
Does that approach seems right?
What would be the most appropriate second ?X? reactor? :rolleyes2:
(apply ''((a b c)(a b c))
vevo.bg
Grrr1337
Re: Link Circle's Radiuses - Using Object Reactor and ??? Reactor
« Reply #1 on: May 16, 2017, 11:02:16 AM »
Ok, this seems to work:
  1. (defun C:LockRadius ( / SS i o )
  2.   (setq *CR_Radius* 50) ; initial radius
  3.   (cond ; Using "CR" prefix ("Circle Radius") for all global variables
  4.     ( (setq SS (ssget "_:L-I" '((0 . "CIRCLE"))))
  5.       (and *CR_Lowners* *CR_Ortr* (mapcar (function (lambda (x) (vlr-owner-remove *CR_Ortr* x))) *CR_Lowners*))
  6.       (and *CR_Lowners* (setq *CR_Lowners* nil))
  7.       (and *CR_Ortr* (vlr-remove *CR_Ortr*) (setq *CR_Ortr* nil))
  8.       (repeat (setq i (sslength SS))
  9.         (setq *CR_Lowners* (cons (setq o (vlax-ename->vla-object (ssname SS (setq i (1- i))))) *CR_Lowners*))
  10.         (vla-put-Radius o *CR_Radius*)
  11.       ); repeat
  12.       (foreach rtr (cdar (vlr-reactors :VLR-Object-Reactor)) (if (= "CircleRadiuses" (vlr-data rtr)) (vlr-remove rtr)) )
  13.       (setq *CR_Ortr* (VLR-Object-Reactor *CR_Lowners* "CircleRadiuses" '((:VLR-modified . CR_Object:CB)))) ; globalise it for the (CR_Editor:CB)
  14.
  15.       (foreach rtr (cdar (vlr-reactors :VLR-Editor-Reactor)) (if (= "CircleRadiuses" (vlr-data rtr)) (vlr-remove rtr)) )
  16.       (VLR-Editor-Reactor "CircleRadiuses" '((:VLR-commandEnded . CR_Editor:CB)(:VLR-lispEnded . CR_Editor:CB)))
  17.     )
  18.   ); cond
  19.   (princ)
  20. ); defun C:LockRadius
  21.
  22. (defun C:UnLockAllRadiuses ( / ) ; DO NOT localise the global variables to remove them.
  23.   (vlr-remove *CR_Ortr*) ; doesn't work if localised here
  24.   (mapcar (function (lambda (x) (vlr-owner-remove *CR_Ortr* x))) *CR_Lowners*)
  25.   ; (foreach rtr (cdar (vlr-reactors :VLR-Object-Reactor)) (if (= "CircleRadiuses" (vlr-data rtr)) (vlr-remove rtr)) )
  26.   (foreach rtr (cdar (vlr-reactors :VLR-Editor-Reactor)) (if (= "CircleRadiuses" (vlr-data rtr)) (vlr-remove rtr)) )
  27.   (mapcar 'set '(*CR_Ortr* *CR_Lowners* *CR_Radius*) '(nil nil nil))
  28.   (princ)
  29. ); defun C:UnLockAllRadiuses
  30.
  31. (defun CR_Object:CB ( ownr rtr args )
  32.   (setq *CR_Radius* (vla-get-Radius ownr)) ; store to pass this flag to the (CR_Editor:CB)
  33.   (mapcar (function (lambda (x) (vlr-owner-remove rtr x))) *CR_Lowners*)  ; remove all objects (from watching) (this is temporarily)
  34.   (princ)
  35. ); defun CR_Object:CB
  36.
  37. (defun CR_Editor:CB ( rtr args )
  38.   (cond
  39.     (*CR_Radius* ; check flag if theres list to process
  40.       (mapcar (function (lambda(x) (and (vlax-write-enabled-p x) (vla-put-Radius x *CR_Radius*)))) *CR_Lowners*) ; apply changes
  41.       (mapcar (function (lambda (x) (vlr-owner-add *CR_Ortr* x))) *CR_Lowners*) ; reinclude all objects in the reactor
  42.       (setq *CR_Radius* nil) ; restore - so it wont stack and to avoid redundant modifications
  43.     ); *CR_Radius*
  44.   ); cond
  45.   (princ)
  46. ); defun CR_Editor:CB
  47.
vevo.bg
Crank
« Reply #2 on: May 16, 2017, 12:13:07 PM »
OK if you've a lot of circles, but have you considered to use constraints?
Grrr1337
« Reply #3 on: May 16, 2017, 12:21:05 PM »
I am aware of dimensional constrants,
Actually I was wondering more about how to construct properly such object reactor - so came up with that simple example.
Other variation might be to link text contents, using the same approach. :)
vevo.bg
« Reply #4 on: May 16, 2017, 01:46:00 PM »
Providing you can prevent a reactor-callback loop, this form of task can be accomplished using a single reactor, e.g.:
  1. (defun c:radlink ( / idx lst sel )
  2.         (if (= "radlink" (vlr-data rtr)) (vlr-remove rtr))
  3.     )
  4.     (if (setq sel (ssget "_:L" '((0 . "CIRCLE"))))
  5.         (progn
  6.             (repeat (setq idx (sslength sel))
  7.                 (setq lst (cons (vlax-ename->vla-object (ssname sel (setq idx (1- idx)))) lst))
  8.             )
  9.             (radlink-callback (car lst) (vlr-object-reactor lst "radlink" '((:vlr-modified . radlink-callback))) nil)
  10.         )
  11.     )
  12.     (princ)
  13. )
  14. (defun radlink-callback ( own rtr arg / rad )
  15.     (if (and (vlax-read-enabled-p own) (setq rad (vla-get-radius own)))
  16.         (foreach obj (vlr-owners rtr) (radlink-updateradius obj rad))
  17.     )
  18. )
  19. (defun radlink-updateradius ( obj rad )
  20.     (if (and (vlax-read-enabled-p obj)
  21.              (not (equal (vla-get-radius obj) rad 1e-8))
  22.              (vlax-write-enabled-p obj)
  23.         )
  24.         (vla-put-radius obj rad)
  25.     )
  26. )
Demo:
Grrr1337
« Reply #5 on: May 16, 2017, 05:15:48 PM »
Wow Lee, thats very clever how you applied the initial radius!
I thought that I would get error for trying to modify a object thats being watched by the object reactor.
So I went with some old advice of yours posted somewhere about wiring-up two reactors.
Not sure but I think that the trick that makes the your routine successful is that you iterate over the all owners, to make modifications,
bypassing the "own" argument inside the radlink-callback ..with.. Some printed results:
(vlax-read-enabled-p own) -> T
(vlax-write-enabled-p own) -> nil
So even if the callback was like this it still works (tested) :
  1. (defun radlink-callback ( own rtr arg / rad )
  2.   (if (and (vlax-read-enabled-p own) (setq rad (vla-get-radius own)))
  3.     (foreach obj (vlr-owners rtr)
  4.       (if (and (vlax-read-enabled-p obj)
  5.         (not (equal (vla-get-radius obj) rad 1e-8))
  6.         (vlax-write-enabled-p obj)
  7.       )
  8.       (vla-put-radius obj rad)
  9.       )
  10.     )
  11.   )
  12. )
So overall the approach I tried may be useful only if its intended to modify the watched object "own",
Such as storing it as a global variable to be processed by the same/another reactor - For instance changing circle's layer if its modified.
Thank you, again! :)
vevo.bg
« Reply #6 on: May 16, 2017, 06:05:11 PM »
Thanks Grrr1337  :-)
Since the owner which triggers evaluation of the callback function has the target radius, the expression (not (equal (vla-get-radius obj) rad 1e-8)) will return false when this owner is processed by the function to update the radius, avoiding the infinite callback loop.
Lee
Grrr1337
« Reply #7 on: May 16, 2017, 08:21:18 PM »
Ah now I see why you did that, however (vlax-write-enabled-p own) would always return nil, i.e. if foreach reaches that same object - that check should prevent attempting the radius modification, but still the radius comparsion would backup the error-proof code (aswell skipping circles that already have the radius).
BTW another alternative could be to use :VLR-AcDb-Reactor with :VLR-objectModified event - but I'm guessing that the callback will be similair to the :VLR-Object-Reactor's - and even less efective since the "watched" objects will be all objects in the drawing (not a relatively small range).
Object reactors seem the hardest type of reactors to work with - but theres also alot of fun.
Overall the main thing I like is that you provide perfect examples that actually work! :D
EDIT: Oh now I visualised what you mean - processing all owners in the callback function in a infinite loop.
« Last Edit: May 17, 2017, 04:44:43 AM by Grrr1337 »
vevo.bg
thanhduan2407
  • Mosquito
« Reply #8 on: June 07, 2017, 12:15:58 AM »
Can you help me if replace "Circle" => Text ?
Thanks Lee Mac very much!
I'm newbie!
Edit: while wait....i have do that. But.....if many Objects => Autocad => Exit.
If i want to save event when later, it can is continue
Can you help me?
« Last Edit: June 07, 2017, 08:34:41 AM by thanhduan2407 »
Grrr1337
« Reply #9 on: June 07, 2017, 03:51:37 PM »
Learning from LM's, the following structure should work:
  1. ; Link the Text Content of the selected objects (only for objects that have 'TextString Property)
  2. ; TxtLinkOn - to enable the reactor
  3. ; TxtLinkOff - to disable the reactor
  4. ; TxtUnLink - to unlink selection (exclude)
  5. ; TxtLink - to link selection (include)
  6.
  7. (defun C:TxtLinkOn ( / L )
  8.   (cond
  9.     ( (not TxtLink:CB) (princ "\nError: \"TxtLink:CB\" not defined.") )
  10.     ( (setq L (_Sel "Select texts to Link: " '((0 . "*TEXT")) nil))
  11.       (_RemoveReactor :vlr-object-reactor "TextLink" nil)
  12.       (TxtLink:CB (car L) (vlr-object-reactor L "TextLink" '((:vlr-modified . TxtLink:CB))) nil)
  13.       (alert (strcat "\n\"TextLink\" Reactor enabled!"))
  14.     ); L
  15.   ); cond
  16.   (princ)
  17. ); defun C:TxtLinkOn
  18.
  19. (defun C:TxtLinkOff nil (_RemoveReactor :vlr-object-reactor "TextLink" T) (princ) )
  20.
  21. (defun C:TxtUnLink ( / rtr sL L)
  22.   (and (setq rtr (_Reactorp :vlr-Object-reactor "TextLink"))
  23.     ; (_Sel "Select texts to UnLink: " '((0 . "*TEXT")) (lambda (o) (vlr-owner-remove rtr o))) ; NOT WORKING - WHY?
  24.     (setq sL (_Sel "Select texts to UnLink: " '((0 . "*TEXT")) nil)) ; The above row is not working, redefine the reactor then!
  25.     (setq L (vlr-owners rtr))
  26.     (progn
  27.       (_RemoveReactor :vlr-object-reactor "TextLink" nil)
  28.       (vlr-object-reactor (vl-remove-if (function (lambda (x) (member x sL))) L) "TextLink" '((:vlr-modified . TxtLink:CB)))
  29.     ); progn
  30.   ); and
  31.   (princ)
  32. ); defun C:TxtUnLink
  33.
  34. (defun C:TxtLink ( / rtr s )
  35.   (and (setq rtr (_Reactorp :vlr-Object-reactor "TextLink")) (setq s (vla-get-TextString (car (vlr-owners rtr))))
  36.     (_Sel "Select texts to Link: " '((0 . "*TEXT")) (lambda (o) (vla-put-TextString o s) (vlr-owner-add rtr o)))
  37.   ); and
  38.   (princ)
  39. ); defun C:TxtLink
  40.
  41. ; Callback Function:
  42.
  43. (defun TxtLink:CB ( own rtr arg / txt )
  44.     (foreach o (vlr-owners rtr)
  45.     (and
  46.       (vlax-read-enabled-p o) (/= (vla-get-TextString o) txt)
  47.     ); and
  48.   ); foreach
  49.   ); and
  50. ); defun TxtLink:CB
  51.
  52. ; SubFunctions:
  53.
  54. (defun _Sel ( msg ssft mapfoo / SS i o L )
  55.   (cond ; prompt for a filtered SS and map a function
  56.     (
  57.       (and
  58.         (princ (strcat "\n" (if (eq 'STR (type msg)) msg "")))
  59.         (setq SS (apply 'ssget (append '("_:L-I") (if ssft (list ssft)))) )
  60.       ); and
  61.       (repeat (setq i (sslength SS))
  62.         (setq o (vlax-ename->vla-object (ssname SS (setq i (1- i)))))
  63.         (setq L (cons (if mapfoo (mapfoo o) o) L))
  64.       ); repeat
  65.       (reverse L)
  66.     )
  67.   ); cond
  68. ); defun _Sel
  69.
  70. (defun _RemoveReactor ( RtrType RtrName msg )
  71.   (foreach r (cdar (vlr-reactors RtrType)) (if (= RtrName (vlr-data r)) (vlr-remove r)) )
  72.   (if msg (alert (strcat "\n\"" RtrName "\" Reactor disabled!")))
  73. ); defun _RemoveReactor
  74.
  75. (defun _Reactorp ( RtrType RtrName ) ; Should return the reactor object if present
  76.   (vl-some (function (lambda (x) (if (= RtrName (vlr-data x)) x)))(cdar (vlr-reactors RtrType)))
  77. ); defun _Reactorp
  78.
Ofcourse no XDATA attaching/detaching nor external .txt file that stores the object's handles - which means it won't work if you reopen the drawing.
vevo.bg
thanhduan2407
  • Mosquito
« Reply #10 on: June 07, 2017, 08:24:40 PM »
Thanks Grrr1337 very much!
I learning from LM's too!
(defun C:LTEXT (/ IDX LST SEL)
  (setq sel (ssget "_:L" '((0 . "*TEXT,MTEXT"))))
  (IF sel
lst
      (Tlink-callback
(car lst)
(vlr-object-reactor
  lst
  "Tlink"
  '((:vlr-modified . Tlink-callback))
nil
  (Alert
    (strcat
      "C\U+00F3 t\U+1EA5t c\U+1EA3 "
      (rtos (sslength sel) 2 0)
      " \U+0111\U+01B0\U+1EE3c link li\U+00EAn k\U+1EBFt v\U+1EDBi nhau"
  (Princ)
(defun c:RLTEXT ()
  (foreach rtr (cdar (vlr-reactors :vlr-object-reactor))
    (if (= "Tlink" (vlr-data rtr))
      (vlr-remove rtr)
  (Alert "\U+0110\U+00E3 x\U+00F3a Link Text")
(defun Tlink-callback (own rtr arg / h)
  (if (and (vlax-read-enabled-p own) (setq h (vla-get-height own)))
    (foreach obj (vlr-owners rtr) (Tlink-updateHeight obj h))
(defun Tlink-updateHeight (obj h)
   (not (equal (vla-get-height obj) h 1e-8))
    (vla-put-height obj h)
However, with multi Object (Ex: Quantity Max > 200 Object) => Program Exit. Report "warning unwind skipped on exception...".
Is there a way to fix this?
Thanks Grrr1337 have reply!
