I have a LISP routine which selects only Open (cons 70 0) polylines and uses them for further work.
I've been using it for quite a few months without a problem but just now I came across a file having open polylines but having (cons 70 128). When I read about the same, I came to know that it means 'Linetype Generation Enabled.'
My question is : whether I should change the selection set command from :-
(setq sspipes (ssget "_:L" '((0 . "*POLYLINE") (70 . 0))))
to
(setq sspipes (ssget "_:L" '( (0 . "*POLYLINE") (-4 . "<OR") (70 . 0) (70 . 128) (-4 . "OR>"))))
or is there any other better way of doing this ?
