Have you seen THIS to help prevent "stalling" cad?
Interesting, approach. I'll try and finagle that into this routine. Looks like it would run within the foreach block I have to process the entities.
Why use selection sets when you can construct lists? Or are you attempting to store this information across multiple sessions?
Right now I'm using two filtered ssget calls to grab all of the insert references and polyline entities. In a rought approach, in a sense, a "list" of entities, correct? Is it possible in AutoLISP to split this "list" into an
n quantity of "sub-lists"? That way I can process each "sub-list" separately.
