Author Topic: Delete Layouts from SideDatabase  (Read 1645 times)
djee
« on: May 10, 2017, 12:39:25 PM »
Is there any way to delete layouts from a sidedatabase? Using the Layout named dictionary instead of the layoutManager? I've been using the below code but it's not deleting the layout itself...
   Public Shared Sub DeleteTab(ByVal MyFileCollection As MyFiles)
        For Each AutoCadFile In MyFileCollection
            Using ExistDatabase As New Database(False, True)
                ExistDatabase.ReadDwgFile(AutoCadFile.SelectedFilePath, FileOpenMode.OpenForReadAndAllShare, False, Nothing)
                ExistDatabase.CloseInput(True)
                Using AcTrans As Transaction = ExistDatabase.TransactionManager.StartTransaction
                    Dim MyLayouts As DBDictionary = AcTrans.GetObject(ExistDatabase.LayoutDictionaryId, OpenMode.ForRead)
                    ' Step through each named layout and Model
                    For Each item As DBDictionaryEntry In MyLayouts
                        If item.Key = "English_Metric" Then
                            Dim MyItem As DBObject = AcTrans.GetObject(item.Value, OpenMode.ForWrite)
                            MyItem.Erase(True)
                        End If
                    Next
                    ExistDatabase.SaveAs(AutoCadFile.SelectedFilePath, DwgVersion.Current)
                    AcTrans.Commit()
                End Using
            End Using
        Next
djee
Re: Delete Layouts from SideDatabase
« Reply #1 on: May 10, 2017, 01:10:28 PM »
Ok, I've just found this answer from _Gile at this location https://forums.autodesk.com/t5/net/remove-layout/td-p/5824050?nobounce. I did not though about changing the working database to the external drawing...
djee
« Reply #2 on: May 10, 2017, 02:06:19 PM »
For some reason, deleting layouts seems to modify the viewports in my remaining layouts...??
   Public Shared Sub DeleteTab(ByVal MyFileCollection As MyFiles, ByVal LayoutName As String)
        Dim currentDatabase As Database = HostApplicationServices.WorkingDatabase
            Try
                Using targetDatabase As New Database(False, True)
                    targetDatabase.ReadDwgFile(AutoCadFile.SelectedFilePath, System.IO.FileShare.ReadWrite, False, Nothing)
                    HostApplicationServices.WorkingDatabase = targetDatabase
                    Using tr As Transaction = targetDatabase.TransactionManager.StartTransaction
                        Dim lm As LayoutManager = LayoutManager.Current
                        lm.DeleteLayout(LayoutName)
                        targetDatabase.SaveAs(AutoCadFile.SelectedFilePath, DwgVersion.Current)
                        targetDatabase.CloseInput(True)
                    End Using
                End Using
            Finally
                HostApplicationServices.WorkingDatabase = currentDatabase
            End Try
        Next
