good morning eveyrone,
I have a .scr that is supposed to take my dimensions styles and set everything in them to "bylayer". When i run it, it returns....
Command: _.dimclre
Enter new value for DIMCLRE <256>: 256
Command: _.dimclrd
Enter new value for DIMCLRD <256>: 256
Command: _.dimclrt
Enter new value for DIMCLRT <256>: 256
Command: _.dimstyle
Current dimension style: Standard Annotative: No
Enter a dimension style option
[ANnotative/Save/Restore/STatus/Variables/Apply/?] <Restore>: _save
Enter name for new dimension style or [?]: Standard
That name is already in use, redefine it? <N>:_yes
Command: nil
Here is the code for the script:
(while ; make list of Dimension Styles
(setq item (cdadr (tblnext "dimstyle" (not item))))
(setq dimstylist (cons item dimstylist))
); while
(foreach dimsty dimstylist
(command
"_.dimstyle" "_restore" dimsty
"_.dimclre" 256 "_.dimclrd" 256 "_.dimclrt" 256 ; all to Bylayer
"_.dimstyle" "_save" dimsty "_yes"
); command
); foreach
Any idea why this might be happening.
Thank you to all in advance.
