Author Topic: Imperial Cad drawings  (Read 1651 times)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« on: May 05, 2017, 03:36:00 AM »
In the U.S.
for Structural ShopDetail drawings
and for platework ShopDetail drawings
What do you guys use for UNITS
Decimal or Engineering ?
How do you define Dimensions
Decimal or Stacked fractions ?
I have a copy of your AISC 'Structural Steel Detailing Manual' from the early 80's but a lot has changed since then.
Can I assume you use lbs for material list mass ?
I hope this is not too much of an 'it depends'  answer, but I can live with that if I have an idea what it depends upon.
Regards,
« Last Edit: May 05, 2017, 03:40:18 AM by kdub »
Called Kerry in my other life
I live at UTC + 13.00
Rob...
Re: Imperial Cad drawings
« Reply #1 on: May 05, 2017, 04:13:32 PM »
I'm pretty sure the answer for most would be Architectural with stacked fractions.
CAD Tech
kdub_nz
  • SuperMod
« Reply #2 on: May 05, 2017, 10:00:15 PM »
Thanks Rob.
I was raised on Imperial "Weights and Measures" until the late 60's - early 70's
... so my brain shouldn't get too twisted
I'll try to get some sample drawings ...
