Googles this lisp sometime back. Was by Tharwat & Kent Cooper.
This lisp changes the linetype scale of the entities & object base on layername. But It does not change those that is inside nested blocks.
I now need it to change those inside nested blocks too.
Need help with the changes to include objects & entities inside nested blocks.
Thank you
(defun c:test (/ ly ss)
;; Tharwat 06.May.2014 ;;
;; altered for list-of-lists approach by Kent Cooper 14 May 2014 ;;
(setq ly '(("Layer1" 0.5) ("Layer2" 0.75) ("Layer3" 1.5)))
(setq ss
(ssget "_X"
(list
'(0 . "CIRCLE,ARC,ELLIPSE,*LINE,RAY,HATCH,REGION")
;; [added RAY,HATCH,REGION (people should avoid Hatching on non-continuous-linetype
;; Layers, but they do honor linetypes and linetype scale) -- any other possibilities? Leaders
;; and Dimensions honor linetypes, but for some reason not linetype scale.]
(cons 8 (apply 'strcat (mapcar '(lambda (u) (strcat (car u) ",")) ly)))
); list
); ssget
); setq
( (lambda (i / sn v)
(while (setq sn (ssname ss (setq i (1+ i))))
(if (vlax-write-enabled-p (setq v (vlax-ename->vla-object sn)))
(vla-put-linetypescale v (cadr (assoc (cdr (assoc 8 (entget sn))) ly)))
); if
); while
); lambda
-1
); if
); defun
