Select all objects on a color
danny:
I've seen a routine like this on the Swamp before, just can't seem to find it. Can anyone help? Select all objects on a color and change layer.
Thanks,
CAB:
Perhaps this one:
http://www.theswamp.org/phpBB2/viewtopic.php?p=39127#39127
danny:
CAB,
That is a great routine, and I also like quick select. But, I need to be able to run it in a script file. Sorry, I should have been more specific.
danny:
o.k I tried this, but got a bad ssget list. What did I do wrong? Just trying to get all object on color 8 and change them to layer xxfine.
--- Code: ---(defun c:c2lay ()
(setq sset
(ssget
"x"
'((62.8))
(if sset
(repeat (sslength sset)
(command "_.chprop" sset "" "layer" "xxfine" "")
--- End code ---
Jürg Menzi:
--- Quote from: danny ---
--- Code: ---'((62.8))
--- End code ---
--- End quote ---
must be:
--- Code: ---'((62 . 8))
--- End code ---
note the spaces...
Cheers
Navigation
[0] Message Index
[#] Next page
Go to full version
