The only luck I've ever had was an independent ditch profile and use a slope to elevation link in combo with the ditch section
split the region is the way to go.on you similar note, thats how we do it clean it up via featurelines and subsurfaces, you can get some of it via alignment widenings, but there is always some small transition that wont work.
