using System;
using System.IO;
using System.Windows.Forms;
#if BricsCAD
using System.Runtime.InteropServices;
using BricscadApp;
using Teigha.Runtime;
using Teigha.DatabaseServices;
using Teigha.GraphicsInterface;
using Teigha.Geometry;
using Bricscad.ApplicationServices;
using Bricscad.EditorInput;
using Bricscad.Runtime;
using CadRx = Teigha.Runtime;
using CadAs = Bricscad.ApplicationServices;
using CadApp = Bricscad.ApplicationServices.Application;
using CadBr = Teigha.BoundaryRepresentation;
using CadDb = Teigha.DatabaseServices;
using CadGe = Teigha.Geometry;
using CadEd = Bricscad.EditorInput;
using CadGi = Teigha.GraphicsInterface;
using CadClr = Teigha.Colors;
using CadWnd = Bricscad.Windows;
#elif AutoCAD
using Autodesk.AutoCAD.GraphicsInterface;
using Autodesk.AutoCAD.Colors;
using Autodesk.AutoCAD.Windows;
using Autodesk.AutoCAD.Internal;
using CadRx = Autodesk.AutoCAD.Runtime;
using CadApp = Autodesk.AutoCAD.ApplicationServices.Application;
using CadAs = Autodesk.AutoCAD.ApplicationServices;
using CadDb = Autodesk.AutoCAD.DatabaseServices;
using CadGe = Autodesk.AutoCAD.Geometry;
using CadEd = Autodesk.AutoCAD.EditorInput;
using CadGi = Autodesk.AutoCAD.GraphicsInterface;
using CadClr = Autodesk.AutoCAD.Colors;
using CadWnd = Autodesk.AutoCAD.Windows;
#endif
[assembly
: CommandClass
(typeof(CsBrxMgd
.Commands))] [assembly
: ExtensionApplication
(typeof(CsBrxMgd
.Commands))]
namespace CsBrxMgd
/// <summary>
/// Class Commands.
/// </summary>
/// <seealso cref="IExtensionApplication" />
public class Commands : IExtensionApplication
#region Public Methods
/// <summary>
/// this is initialized when the application is loaded
/// </summary>
public void Initialize()
Document doc = CadApp.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
Database db = doc.Database;
ed.WriteMessage("\nCsBrxMgd sample is loaded...");
/// <summary>
/// this is initialized when the application is terminated
/// </summary>
public void Terminate()
CadApp.ShowAlertDialog("The commands class is Terminated");
[CommandMethod("CopyObjectsBetweenDatabases", CommandFlags.Session)]
public static void CopyObjectsBetweenDatabases()
string filePath = @"c:\users\kbrown\desktop\New Drawing.dwg";
Database destDb
= new Database
(false,
true); Database sourceDb = CadApp.DocumentManager.MdiActiveDocument.Database;
destDb.ReadDwgFile(@"c:\users\kbrown\desktop\CopyViews.dwt", FileOpenMode.OpenForReadAndWriteNoShare, false, null);
destDb.CloseInput(true);
string myFileName = (string)CadApp.GetSystemVariable("DWGNAME");
string myFilePath = (string)CadApp.GetSystemVariable("DWGPREFIX");
string _originalFile = Path.Combine(myFilePath, myFileName);
string blockName = Path.GetFileNameWithoutExtension(_originalFile);
ObjectId xrefId = destDb.AttachXref(_originalFile, blockName);
HostApplicationServices.WorkingDatabase = destDb;
BlockTableRecord destModelSpace;
ObjectIdCollection idCollection
= new ObjectIdCollection
(); using (Transaction tr = destDb.TransactionManager.StartTransaction())
using (BlockReference br
= new BlockReference
(Point3d
.Origin, xrefId
br.SetDatabaseDefaults();
br.Layer = "0";
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(br.BlockTableRecord, OpenMode.ForWrite);
string relativePath = MakeRelativePath(filePath, _originalFile);
btr.PathName = relativePath;
BlockTable bt = (BlockTable)tr.GetObject(destDb.BlockTableId, OpenMode.ForRead);
destModelSpace = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
destModelSpace.AppendEntity(br);
tr.AddNewlyCreatedDBObject(br, true);
tr.Commit();
HostApplicationServices.WorkingDatabase = sourceDb;
using (Transaction tr = sourceDb.TransactionManager.StartTransaction())
ViewTable vt = (ViewTable)tr.GetObject(sourceDb.ViewTableId, OpenMode.ForRead);
foreach (ObjectId id in vt)
idCollection.Add(id);
tr.Commit();
try
BlockTable destBt = (BlockTable)tr.GetObject(destDb.BlockTableId, OpenMode.ForRead);
destModelSpace = (BlockTableRecord)tr.GetObject(destBt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
IdMapping mapping
= new IdMapping
(); destDb.WblockCloneObjects(idCollection, destModelSpace.ObjectId, mapping, DuplicateRecordCloning.Ignore, false);
catch (Exception ex)
MessageBox.Show($"Error in wblockclone:\n{ex.Message}");
tr.Commit();
destDb.SaveAs(filePath, DwgVersion.Current);
public static string MakeRelativePath(string fromPath, string toPath)
string relativePath = toPath;
try
Uri fromUri
= new Uri
(fromPath
); Uri toUri
= new Uri
(toPath
); if (fromUri.Scheme != toUri.Scheme)
return toPath;
} // path can't be made relative.
Uri relativeUri = fromUri.MakeRelativeUri(toUri);
relativePath = Uri.UnescapeDataString(relativeUri.ToString());
if (toUri.Scheme.ToUpperInvariant() == "FILE")
relativePath = relativePath.Replace(Path.AltDirectorySeparatorChar, Path.DirectorySeparatorChar);
catch
return relativePath;
#endregion Public Methods
