Author Topic: Overkill isn't working  (Read 3436 times)
Fabricio28
« on: April 18, 2017, 02:32:08 PM »
Hi all
How are you?
I want to know how to use OVERKILL to remove duplicate or overlapping lines, arcs, and polylines.
I couldn't remove duplicate arcs and polylines from my drawing.
File is attached
Fabricio
ChrisCarlson
Re: Overkill isn't working
« Reply #1 on: April 18, 2017, 03:16:43 PM »
Your main arc does not have an underlying arc. They are two separate entities with different start and end points.
Fabricio28
« Reply #2 on: April 18, 2017, 03:22:00 PM »
Thanks for replay.
There are lines and arcs overlaping and I don't know how to fix it.
« Reply #3 on: April 18, 2017, 03:36:11 PM »
You might try the flatten command. If I remember correctly it may combine some objects.
« Reply #4 on: April 18, 2017, 03:39:58 PM »
Fabricio28
« Reply #5 on: April 18, 2017, 03:52:12 PM »
I take that back, Overkill is the one I was thinking about.
Maybe your tolerance setting it too small.
https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/AutoCAD-LT/files/GUID-0916FE53-F816-4C40-AA5E-5E8CBFD7F73F-htm.html
Thanks CAB
Combine End to End
Objects that have common endpoints are combined into single objects.
The lines isn't have common endpoints in my drawing.
So I can't remove these lines.  :cry:
MSTG007
« Reply #6 on: April 18, 2017, 04:30:08 PM »
That would be cool if there was a way to do that.
Civil3D 2020
Fabricio28
« Reply #7 on: April 18, 2017, 05:50:46 PM »
I totally agree. :-)
Fabricio
dtkell
« Reply #8 on: April 18, 2017, 06:22:12 PM »
Will not the "combine linear objects that partially overlap" not work because of being arcs?
\"What sane person could live in this world and not be crazy?\" -Ursula K. Le Guin
« Reply #9 on: April 18, 2017, 06:25:06 PM »
« Reply #10 on: April 18, 2017, 06:30:51 PM »
Another one to look at:  http://www.totalpurge.com/
I have not tried nor endorse this programs just did an internet search for you.
MSTG007
« Reply #11 on: April 18, 2017, 07:03:55 PM »
I gotta try this out tomorrow. Thanks for the find CAB.
Civil3D 2020
