Author Topic: MSLIDE HELP  (Read 1239 times)
pedroantonio
MSLIDE HELP
« on: April 08, 2017, 10:42:18 AM »
Hi I need to make a slide. I write  mslide in the command line and export a *.sld. When i  run the command vslide i see a continuous line and not my line. I try again ang again with diferent zoom or line scale but all the times a take the same results. I don't know were is the problem. I attach  a dwg  with the line , and one sld  i export.I don;t know if the problem is with my autocad !!!
Can any one make the slide
Re: MSLIDE HELP
« Reply #1 on: April 08, 2017, 10:55:35 AM »
Linetypes will not be represented when creating a slide file, only the object geometry is considered.
To obtain the desired result, you will need to 'explode' the linetype to yield separate lines before creating the slide - you can do this using the WMFOUT & WMFIN commands.
pedroantonio
Re: MSLIDE HELP
« Reply #2 on: April 08, 2017, 11:11:02 AM »
thanks lee
