Author Topic: Find shorest distance path  (Read 2038 times)
mohan
« on: April 06, 2017, 01:48:16 AM »
Hi;
Is there any Program for the below Image:
Find the shortest distance for point A to B
thanks
mohan
"Save Energy"
ribarm
  • Marko Ribar, architect
Re: Find shorest distance path
« Reply #1 on: April 06, 2017, 04:59:45 AM »
Your problem is very complex according to your posted picture, but for simple tree branching I strongly suggest that you read and analyze this topic very carefully...
https://www.theswamp.org/index.php?topic=45092.0
M.R. on Youtube
VovKa
  • Ukraine
« Reply #2 on: April 06, 2017, 06:08:12 AM »
in case you are using Civil3d or Map3d
https://www.theswamp.org/index.php?topic=31050.msg366521#msg366521
mohan
« Reply #3 on: April 06, 2017, 10:26:21 AM »
I am using civil_3d
many thanks guys for the suggestion to my thread, I will go throw the links
mohan
"Save Energy"
BIGAL
  • 40 + years of using Autocad
« Reply #4 on: April 06, 2017, 11:03:56 PM »
There is a lot of theory on route mapping the simplest example is to just turn on your mobile GPS and ask go from Pt A to Pt B. If you google this theme I am sure you will find all sorts of mathematical models on how to do this. Putting into Autocad ? It is more likely that you will find a 3rd party program that analyses a series of strings. Then read that answer back into Autocad.
VovKa
  • Ukraine
« Reply #5 on: April 07, 2017, 05:47:20 AM »
map3d (civil3d) has all that functionality built-in
one must first create a network topology then use _MAPANTOPONET command
BIGAL
« Reply #6 on: April 17, 2017, 01:29:18 AM »
Never to old to learn something new. Just so many commands.
