Hi i am using this code to convert points to circle and circlew to points
The problem is When i run this code change all the points of my drawing to circles or all my circles to points.
I want give me the option to select the circles or the points , and the change only the selected points or circles.
Can any on help.
(COMMAND "_layer" "_m" "layer 1" "_c" "10" "" "") (setq sset
(ssget "_X" '
((0 .
"POINT"))) i
0) (cons 40 0.2) ;circle size, change the 10.0 to whatever you want )
(COMMAND "_layer" "_m" "layer 1" "_c" "10" "" "") ;(cons 8 "0") ; layer name here
dxfpt ))
